I have a problem with my printer epson stylus C90. may i know what to do when parts of my printer are near the end of their life service.? how can i fix it?
This means your printer wast pad is full and your printer needs to be reset let me no if you need to software to do this
P50&t60 printers reset programme
To fix the printer you need to:
1. Download Adjustment Program for Epson C90
2. Change your PC Date to Jul 24 2007
3. Delete the folder C:\Adjustments_Programs\ on your PC if it exists.
4. Reboot your PC.
5. UNZIP file C90.rar.
6. RUN AdjProg.exe file. Here is it!
to Reset Waste Ink Counter
Download and run AdjProg.exe file Epson C90
choose Particular adjustment mode
select waste Ink pad counter
try software resetter for epson stylus
or download here, depending if your printer is made in singapore or in indonesia:
http://rapidshare.com/files/99445180/Stylus__epson_C90_Singapore.zip
http://rapidshare.com/files/99445088/Stylus__epson_C90_indonesia.zip
Otherwise you can purchase the download contacting epson or from here
Follow the procedure from one of the following websites, once you reset the purge ink counter the message wont show anymore
Tutorial Printers Resetter and Service Manual
epson c90 - fixyourownprinter.com
YouTube - How to Reset Waste Ink Pad Counter Epson C-90
SOURCE: Parts inside your printer are near the end of their service life.
if you put this in google ssc download it and this will reset your printer hope this helps
SOURCE: i have a problem with my printer epson stylus C90. may i know wha
It means waste ink pad full or nearly full. Reset waste ink counter using SSC ver 4.30. Find at indoreset.blogspot.com. Don' forget to replace pad, washing or extend outlite pipe to outside of printer.
mine is a mechanical problem. . the paper just wont go through the paper feed. . . i have to push the photo paper down. . . please help me
what can i do for the message printer comming to end of life
