When I try to scan something on my HP c3180 All-in-One printer, it scans okay, but then when I try and import the scanned item, it comes up with this message saying "device not ready. . .error" and it asks me to choose one of three options: "try again," "skip this file," and "skip all files with errors". Then it has buttons for continue and cancel. If you press try again and then continue, nothing changes. The same window pops up every time you click continue. What's going on? And how do I fix it? Please help.
SOURCE: hp 2700 series all in one printer scanning issues
Hi .
Let me first explain that the scanning softwareis seperately loaded into the computer which is called as Digital Imaging. Try the step below:
1. try scanning from scanners and cameras - 2 errors might pop up if it does not scan - an error occurred communiating with the scanning device / no HP device detected.
2. start - programs - locate for a software loaded called HP Solution Centre / HP Director.Open the software if loaed and try to scan from there. If its not loaded then insert th installation cd and click on Install more software - full.
3. In HP solution Centre / Director click setting - scan settings - scan to ..... setup - see that both the columns of front panel and available destination list should be having some icons into it (you can add and delete from any column as desired - but none should be empty)
Click the link below to ssist you with relevant troubleshooting -
http://h10025.www1.hp.com/ewfrf/wc/documentSubCategory?rule=40990&lc=en&cc=us&dlc=en&product=420428&lang=en
If none of the above work then try uninstalling and re-installing the printer software all over again
SOURCE: HP PSC 2355 all-in-one scanning problem
hi shaundoyle -
first, I wanted to point you to HP's general support page for your model:
http://h10025.www1.hp.com/ewfrf/wc/product?product=422000&lc=en&cc=us&dlc=en&lang=en&cc=us
here is another link, this one to a doc for connecting to more than one HP product using a Mac:
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&cc=us&docname=bpm01356&dlc=en&product=422000
here's a link to a doc about the scanning stopping:
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&cc=us&docname=c00803473&dlc=en&product=422000
and yet another link, this one for probs printing through 'classic' applications:
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&cc=us&docname=c00035422&dlc=en&product=422000
it sounds like one piece of software overwrote another, or your two pieces of hardware are fighting each other for your Mac's attention. hope this helps a little.
-JW50
What does "OS" mean?
It's a windows.
Yes it is.
Windows XP Vista?
Is your computer Windows, Mac, Linux .. ?
What OS?
