This is most likely the anti theft security system failing and shutting down the starter. Check out this link for info, pics, and ways to fix this yourself. http://vatspasslockpasskeysecurityhelp.yolasite.com/
It sounds as if you still have a problem with the anti theft system. Possible loose switch wiring in the dash or it was programmed and cycled incorrectly.
it does sound like the anti-theft system. There are only 2 ways to bypass your problem. 1) disconnect the anti-theft system which runs into your ignition, cut the wires to the system and join them back together without hooking it back up to the anti-theft. 2) Bring it back to the dealer so that they can replace your anti-theft sensor. The part is rather cheap but the labor is the killer.
if the vehicle starts then stops and the anti-theft light is flahing you may need to re-set the pass-key system to do this you will need to atempt to start the vehicle and when it stalls leave the key in that position and watch the anti-theft light. it should flash on and off for about 5 to 10 minutes. when it stops flahing turn the ignition to off then try to restart your vehicle
