Yamaha Waverunner Xl 700 Xl 760 Xl 1200 Jet Ski Cover Logo
Posted on Jun 30, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Where is my starter located - Yamaha Waverunner Xl 700 Xl 760 Xl 1200 Jet Ski Cover
RAYMONDO1953
Level 2:
Prodigy:
An expert who has answered 500 questions.
  • Yamaha Expert 545 Answers
  • Posted on Jun 13, 2014
RAYMONDO1953
Yamaha Expert
Level 2:
Prodigy:
Answers
545
Questions
Helped
106939
Points
669
Itmay be a dyna start
2answers
Where is the starter solenoid located on a 2002 Buick LeSabre
on the side of the starter motor.
starter relay is the other part not there.
relays are in fuse/relay box.
no cranks have 6 causes.
Location of starter relay for a 2010 4 cylender touring sebring
The starter relay is called the starter solenoid and is located on the starter motor.
1helpful
Where is starter located?
The starter is located on the lower side of the motor. Disconnect negative battery cable. Raise and support vehicle. Remove flywheel cover (s). Disconnect starter solenoid wiring. Remove starter mounting bolts. Remove shims and note arrangement for reassembly (if equipped). Remove starter assembly. To install, reverse removal procedure. Ensure shims are installed in original location (if equipped). Tighten fasteners to specification. Starter Bolts 35 Ft. Lbs, Flywheel Cover Bolts 89 Ft. Lbs, Positive Battery Cable-To-Solenoid Nut 89 Ft. Lbs, "S" Terminal Nut 37 Ft. Lbs
1helpful
Chevy hhr starter location
Starter located on the engine, from under car look between engine and radiator, where engine connects to transmission, that is the starter. Check links below, press the helpful button
Chevy HHR starter location and removal
Going under the Chevy HHR
How to Test and Troubleshoot Starter Problem
Time to replace starter 07 HHR 2 4L Chevy HHR Network
6helpful
3answers
How to locate starter solnoid for a 1999 chevy tahoe v-8 4 wheel drive.
starter solenoid is usually located on the starter on all GM products. There is also a starter relay in the fuse box located under the hood of your particular vehicle.
Where is the starter located on my 1995 cadillac sedan deville
The location of the starter is as per the car engine.If its 4.5 liter then starter is located on front bottom of the engine.And if its 4.6 liter engine then starter is located under the intake manifold. And On the 4.9 liter the starter is located on the bottom side of the engine. ------------ This will help.Thanks.Helpmech.
The motor clicks all lights and power come on but i am unsure of the location of the starter
The starter is usually located on the side where battery sits. The best way to determine where the starter is located, follow the positive cable toward engine. The positive wire usually connects to the starter. Occasionally, the starter may be located on the opposite side of engine. In either case, simply following the positive cable will lead you to the starter.
1helpful
2answers
Where is the starter solenoid located on a 1994 bmw 525i
The starter solenoid is located on the starter. It looks like a miniature version of the starter which is attached to the starter. The starter relay, however, is located in your engine compartment on the passenger's side under the black box which also houses your cars main computer. This black box is located towards the back of the engine compartment (close to the windshield) on the passenger's side. There are 4 philips head screws which hold it in place.
16helpful
2answers
2004 mazda 6 starter
the starter is located on top of the engine, underneath the battery and battery tray. they must be removed to gain access to the starter
7helpful
3answers
1999 olds aurora starter
The starter is located under the intake manifold.
Top Yamaha Boating Experts
neil
Stan Ford
Are you a Yamaha Boating Expert? Answer questions, earn points and help others
