Change your sentence from, where do I find, to I need to find a carburetor diagram for poulan pro curved boom trimmer model number 952-271-1961 and do an online search. It don't get too much easier than that.
First step is to take the gas cap off and tip the mower to pour the old gas out. Leave the cap off for awhile and let the rest of the gas evaporate. After you have handled this, pull out the spark plug and pull the started a few times. This will push whatever gas is left in the carb and lines into the cylinder where it can evaporate or spill out of the spark plug hole.
Start under poulan/weedeater then choose: / poulan pro / saw / gas / then choose your model number. It will bring up a parts diagram of your chainsaw.
Add the part to the cart by changing the Qty to 1 and then add to cart. You will then see the part and the price
There are so many different Poulan Pro model numbers that I can not even begin to guess your model.
Please note that there a few different "Types" of 260, so if this isn't the one you've got, try selecting "Poulan" from the Brands list at the top of the page and then looking through the available models until you find the "Type #" you have.
Drain plug is under the motor. tip the hole machine back, (handle lying on ground) put something heavy on handle to hold it down, the plug usually is a 1/2 size wrench. Put a pan under machine to catch the oil. Take the drain plug out, drain oil, put drain plug back in, tighten it, and put machine back on all four wheels. Add oil. Take about 3/4 quarters of a quart. SAE 30 or 10w-30.
Since You weren't Model Specific...I assumed you meant a Poulan Pro 38cc, here's a Contact Site for OEM Manuals: http://www.poulan.com/poulanpro/manualSearchResultsAJAX.do
How do I change the oil?
