SOURCE: problem getting panel lock unlocked on combi tv
need to turn volume up but panel lock wont let me and i have have no manual
SOURCE: how do i unlock the
Hello
Unlocking your Samsung TV requires access to the Samsung TV service menu, which will allow you to reset or remove any previous lock in the settings. In order to unlock your Samsung TV you will need your remote control. All you have to do is simply follow the instructions provided below and you can use the service menu to guide you from there. Also note that upon entering the Service Menu, all User Menu settings will revert to factory default
Steps To Unlock A Samsung TV
1. Turn the power off.
2. On the remote, press Mute followed by 1, 8, 2, Power in sequence.
3. You should now see the service menu. To exit the Service Menu always select RESET.
You must have its orginal remote control with you to perform these functions. If you haven't it with you, contact Samsung Electronics at your country.
OK.
SOURCE: how do i find the code for my samsung TV/video
Hello
Four digit universal remote codes for Samsung TV/DVD combo are:
0455 0963
TV/VCR combo are:
0358 0942 0942
Direct Code Entry
