How can i get my HP photosmart C4680 printer to unpause
Its on. its connected. it wont print
  • 14,827 Answers
Unplug it
Posted on Jan 10, 2016
5 Suggested Answers
Anonymous
SOURCE: Can't scan on HP Photosmart C4380 even tho printing works fine
I am sick and tired of the problems i have with this PSC, but i have found a scanning solution and thought i would share it.
Use Microsoft Paint. It's not the best application in the world, but you can insert a scan from a scanner in the 'file' menu. :0) The scans are not of the best quality, but i'm grateful i can scan at all with this useless PSC.
Posted on Apr 18, 2009
ultimitloozr
  • 489 Answers
SOURCE: HOW WILL I UNPAUSED MY PRINTER?
There should be a printer icon in the notification area. You can double-click on that to bring up the printer status. If the icon is not there, you can go to Start -> Control Panel -> Printers and double-click on your printer. The first item in the print queue should be listed as paused. Right-clock on it and select Resume from the context menu.
Posted on Jul 10, 2009
Norman Al-Anbar
  • 630 Answers
SOURCE: "incompatible cartridges"
Usually if you leave the printer off for sometime the ink get dry on the heads or some ink may leake to the sensores so take the cartrage out clean it and clean the heads with cotton swaps...see if the help and let me know
Posted on Sep 13, 2009
Anonymous
  • 83 Answers
SOURCE: HP Photosmart C4585 printer says print cartidges
Try to verify if it recognises the catridges you have. If not, clean the contact pins and try to fix it again.
Posted on Jan 13, 2010
michaelshaun
hamid abdul quddus
  • 126 Answers
SOURCE: I have a new HP C4680 printer. When I print from
try printing a test page from the printer and if it works fine you need a software(HP smart web printing )
and you will get the software in the following website :
www.hp.com/go/smartwebprinting and there would be instructions given in the same page download and install the printer software and try printing from the internet using teh software and it shoul print perfect though it is complicated but this has been the best resolution for printing online
hope you liked the software and everything works fine
if you still have questions get back to us and we will surely help you
thanks
regards
Hamid
Posted on Feb 20, 2010
Hp photosmart c4680
The HP C4680 is a powerful all-in-one printer that combines an easy interface and connection process with powerful printing capability.
With a small time investment and minimal effort, even the least tech-savvy home user among us can have their HP C4680 up and running in no time, and take full advantage of all of its printing power.
Connect the AC adapter from the AC terminal on the upper right-hand side of the back panel of the printer to an electrical outlet or surge protector.
Power on the printer using the power button on the front panel of the printer and specify language and country preferences using the prompt on the main display of the printer.
Remove the pink tape from the print heads on the provided ink cartridges.
The tape should come off easily with gentle pressure.
Install the cartridges by opening the main door on the front of the printer and placing the cartridges into the cartridge cradles.
The HP logo should be facing up. Push the cartridge into the cradle until it clicks into place.
Attach the USB cable from the printer's USB port to a USB port on your computer and power on the printer.
Install the setup CD that came with the printer into your computer's CD-ROM drive and follow the steps for installing the printer software on your computer.
Your HP C4680 is now set up and ready to use.
HP Printer Driver Packages
http://h20000.www2.hp.com/bizsupport/TechSupport/ProductList.jsp?lang=en&cc=us&taskId=135&prodTypeId=18972&prodSeriesId=25523
Aug 09, 2013 | Computers & Internet
How can I unpause my printer?
Locate the printer you are using like this by clicking on "Start" - "Control Panel" - "Hardware and Sounds" - "Printers". Right click on the printer in question and select "Resume Printing" since it was paused before. Good luck.
Jun 30, 2012 | HP Photosmart C4680 Q8418A InkJet MFC /...
I have a HP Photosmart C4680 All-in-One Printer. When I connect it to my laptop and turn it on, it starts to do things by itself...like someone is remotely using it to scan, copy or print. I am still...
check for a pending job on your computer, or when it print when you turn on it print a sample page? if so put it face down on the scanner then press the scan button then wait till the power light go on steady,
Aug 09, 2011 | HP Photosmart C4180 All-In-One InkJet...
HP Photosmart C4680 prints only in Black and White
Make sure in the printer properties it is not set to print in b&w only.
Mar 25, 2011 | HP Office Equipment & Supplies
I have an HP photosmart C4680. It keeps turning on and off by itself. I checked the plugs, they are not loose.
http://h30434.www3.hp.com/t5/Other-Printing-Questions/HP-Photosmart-C4680-Problem/m-p/622051#M35537
Jan 10, 2011 | HP Office Equipment & Supplies
I need to print a mirror image
Do you want to print in Mirror Image ?
Follow the steps and you will be able to do so,
Click on Start button
Open Control Panel
Open Printers
Highlight the Printer icon name ( HP Photosmart C4680 All-in-One Series )
Right click on the Printer icon and Left click on Printing Properties
Under Advanced Tab click Mirror Image ON
Click Apply - Click OK
Try to print and it will print in Mirror Image.
Thank you for contacting Fixya
*Please rate this solution with thumbs up
Nov 20, 2010 | HP C4680 All-In-One Inkjet Printer
Find a user manual for HP Photosmart C4680
You can download the required manual from:
HP Photosmart C4680 support Hope this solves your problem. For more help and clarifications, please reply to this post. Thanks
Oct 10, 2009 | HP Computers & Internet
173 people viewed this question
jasbo
jasbo
Ekse
Marvin
Marvin
