Downloaded Windows XP and now i cannot access the internet because i cannot enable the wireless lan or the ethernet connection. unknown prior administrator and prior admin password. how can i reset or bypass this
Go to the link below and download Ophcrack and burn the iso to a cd.
Boot from the CD and let it do it's magic. You'll have the password
shorthly:
http://ophcrack.sourceforge.net/download.php
SOURCE: can't connect to internet through wireless
Dell XP Installation CDs are the same for all systems, the drivers for different systems are contained on the Resource CD for that system. Dell also usually places the drivers for the system in a specific location on the hard drive to be reinstalled later if needed. It depends on the type of installation you performed.
If you did a Repair Installation, the underlying files and programs would have remained intact and the correct drivers would be found in the c:\dell\drivers folder from the original installation. However, if you did a Full Installation you must do one of the following:
1) locate the Resource CD for your Inspiron 6400 and install it;
2) see if 'Local Area Connection' shows under the Start button->My Computer->Connect To->Show All Connections menu, and if so just hook to the router or modem by an ethernet cable until you download the drivers from Dell's website (support.dell.com);
3) download the drivers from Dell's website (support.dell.com) on a different machine and copy them to a USB memory stick or cd, then insert the media into the Inspiron 6400 and install the drivers;
or
4) install a USB or PCMCIA wireless card or ethernet connector just to get you online so you can get to the Dell site to download the correct drivers. You probably know someone you can borrow such a device from rather than pay the $30-$40 to buy it new. Once the correct drivers are installed you wouldn't need it again.
SOURCE: Dell inspiron E1505 cannot connect to internet
A hardware error usualy indicated a bad network cable or a bad network card. Have you tried using a different Cable?
SOURCE: Ethernet port not "active"
Hi there.
Restart the PC and go into the bios to make sure the on-board LAN is enabled, if it is try as jery says and try another ethernet cable.
Post back please and good luck
SOURCE: Forgot username for admin acc in windows xp
Forgetting your Windows administrator login password. With no way to get into the system, you can’t even perform basic maintenance, let alone a thorough tune-up. Formatting is always an option, but we consider that a last resort. (Plus, guess who’s going to have to help reinstall all the programs lost after a wipe?) But all hope is not lost. There are a few ways to actually retrieve a lost Windows account password. Read on, and we’ll show you the light.
1st Method:
The first thing which you check if you forget login password. When we install Windows, it automatically creates an account "Administrator" and sets its password to blank. So if you have forget your user account password then try this:
Start system and when you see Windows Welcome screen / Login screen, press ctrl+alt+del keys twice and it'll show Classic Login box. Now type "Administrator" (without quotes) in Username and leave Password field blank. Now press Enter and you should be able to log in Windows.
Now you can reset your account password from "Control Panel -> User Accounts".
Same thing can be done using Safe Mode. In Safe Mode Windows will show this in-built Administrator account in Login screen.
2th Method:
There are a lot of Windows password revealers and crackers available, but we’ve found that Windows Password Recovery Tool is the most effective.:
Windows Password Recovery Tool is one of the easiest password recovery tools to use. It allows you to reset a user account password, including the Administrator password. It is also a relatively small download.
Windows Password Recovery Tool Service: http://www.windowspasswordsrecovery.com
SOURCE: My mom got a Dell Studio 1535 laptop for my sister for
no need to go in deep so much
while starting up of the laptop, press <Del> key or <F2> to go to setup.
select security setup
change security setup to other than system
and disable/clear passwords if possible, by giving blank passwords
you will solve your problem if you follow the aforesaid things
