I am remodeling my kitchen and have moved the old GE side/by/side from the garage to my make shift kitchen. GE TFX22R. It sits unlevel but from reading on line..... maybe a refrigerator does not need to be level.?? There are no "little" feet as far as I can tell to adjust. The fresh food door doesn't always close all the way. Any advice on adjusting the level or the door. Thank you. But what if it's the back that's too low and the front levelers are as far down as they will go?
The refrig does not have to be level, as a matter of fact, they tend to work (doors on most refrig's) if the front is a bit higher than the back. If you pop off the lower grill, you will see that the front rollers have a bolt that runs up through the lower frame. Turning on the end of that bolt with a 3/8 inch wrench will allow adjustment of an inch or so, up or down, depending on where it is at now. Only the front rollers are adjustable this way. Back rollers would have to be shimmed to adjust. Check the door hinges to see if the hinge and corresponding hinge cam riser (WR2X4901) are worn. (these parts raise the door slightly as it is opened, and help close the door as the door drops back down when closing.)
