Texas Instruments TI-84 Plus Silver Edition Graphic Calculator Logo
Jenny Maldonado Posted on Jun 29, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Everytime I try to do powers and square roots I get an error message
The message says err:memory. I get this message whenever I try to square a number or raise it to any power and when I try to find the square root of a number. Help please?
k24674
Level 3:
  • Texas Instru... Master 8,093 Answers
  • Posted on Jul 01, 2012
k24674
Level 3:
Answers
8093
Questions
0
Helped
4673136
Points
21595
An ERR: MEMORY is given when there is not enough memory to perform the instruction or function. To increase available memory by deleting the contents of any variable (real or complex number, list, matrix, Y= variable, program, Apps, AppVars, picture, graph database, or string), follow these steps. • Press [2nd] [MEM] to display the MEMORY menu.
• Press 2: Mem Mgmt/Del.
• Select a variable or data that needs to be deleted and press [ENTER].
• Use the arrow keys to move the cursor next to the item, and then press [DEL]. The variable or data should now be deleted from the memory.
When deleting programs or Apps, a message asking for confirmation will appear. Select 2:Yes to continue. To leave any variable screen without deleting anything, press [2nd] [MODE].
5 Related Answers
Anonymous
  • 12 Answers
  • Posted on Feb 16, 2009
SOURCE: ERR:SYNTAX
try to change the mode to function otherwise im stumped
Anonymous
  • Posted on Mar 15, 2009
SOURCE: Graphing radical functions
I have a TI-89 Titanium and I have experienced the same problem. HERE IS HOW TO FIX IT:
Goto " MODE " and scroll down the options until you get to
" COMPLEX FORMAT " change that option to " RECTANGULAR " and press ENTER until you exit out of the " MODE " screen. (very important that you press ' enter ' until you exit because if you don't, it will not save your changes. )
k24674
  • 8093 Answers
  • Posted on Sep 07, 2009
SOURCE: TI-15 square root Function
You should enter it as follows [SQRT]36 ) [ENTER/=].
If you define some function f of a variable x you write that f(x), where the parentheses enclose the so-called argument (objet on wich the function acts). It seems that on this calculator the opening parenthesis is implicit: the calculator supplies it when you press [SQRT] but does not display it (a design flaw?). However the closing parenthesis must be entered by you to signifie to the function [SQRT] that you have finished entering the argument. Weird but one can live with it.
Hope it helps.
Anonymous
  • Posted on Feb 18, 2010
SOURCE: On my TI-30xs Texas Instruments, I cant figure out
Use the toggle button above the enter key. It looks like 2 arrows
  • 102366 Answers
  • Posted on Apr 01, 2010
SOURCE: The TI-84 Plus Silver Edition - when dealing with
Press the MATH key to bring up the Math menu. Option 3 gives you cubed, option 4 gives you cube root, option 5 gives you nth root.
For example, 3rd root of 8: MATH 4 8 ENTER gives 2.
4th root of 16: 4 MATH 5 16 ENTER gives 2.
Testimonial: "thank you thank you so much!"
Not giving proper awnsers for square root questions
Contrary to what you believe, results with square roots are exact. Decimals are approximate.
Press the SD key to convert from standard to decimal representation.
How can I slove the error ERR:DATE TYPE when I try to run a program I have written?
You're attempting an operation that is not valid for a particular data type, like taking the square root of a string or extracting the second character of a floating-point number.
First, localize the error. Find the line number or location of the error, then narrow it down to the operation. Then examine the value(s) being used in that operation and their types. Make sure the operation is valid for that type(s).
Insufficient storage message on samsung galaxy s3 rooted phone
delete some item from phone memory, change save position
5helpful
How do I use the calculator on the LG Octane? I want to use the square root function and keep getting an error message.
sqrt is really the root. to get the square root, you have to tell the calculator that it is the 2 root. So, to get the square root of 9, simply enter "2" <operators><sqrt> "9" and the answer displayed is 3. Note, the number 2 followed by the operators soft key, followed by selecting the sqrt option followed by the number 9, followed by the =.
I'm getting a error message that says, "ERR 99".
Welcome to Fixya
Err 99 could mean several different things, such as... Memory Card, Lens or Lens contacts....
Here's what you can try:
Remove the memory card an enable "shooting with out memory card" and see if you still get the error. If it works your memory card is bad. Try another lens if you can. Clean the lens contacts with a pencil eraser (be careful not to get eraser dust in the camera body or in the lens). Worst case scenario is, Err 99 could be related to the shutter failing which would mean a trip to Canon.
Thanks
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
4helpful
Square Root
Don't forget to close the parentheses.
To compute the square root of 2, press SQRT 2 ) ENTER
Abs( and square roots
The missing error means that you did not close the parenthesis. When you use a square root or absolute value it always gives you the left parenthesis, (, but you need to close it with a right parenthesis, )
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Jerry Naidoo
Paul Bade
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
