No remote for Goldstar 8mm VHS VCR recorder player
I just picked up this unit from a thrift store to use to play/record my 8mm tapes but it did not come with remote. We can't get the unit to switch to 8mm mode, it only plays VHS tapes and when we insert the 8mm tape it immediately ejects the tape. Is this problem fixable without a remote and do we even need the remote to use the machine at all? Thank you for this site and help!
You need an 8mm player or the camera that recorded the tapes. Connect the video and audio from the 8mm player/camera to a VHS recorder. Put the 8mm on play and the VHS on record.
If the entire VHS is full then you can easily transfer the VHS contents to the DVD. The video will play while it is recording onto the DVD, but you don't have to have it hooked up to any TV for it to record. Now if you don't know how long the VHS content is that you want to record to DVD, then you will have to hook up the player to a TV so that you can press stop when you reach the end of the content you want recorded. At least this is true in the way that I use to transfer VHS to DVD:
1) Turn on the unit 2) Insert VHS tape 3) Insert DVD-+R or DVD-+ RW 4) Using remote, press VCR 5)Using remote, press play then pause the tape where you want to start recording. 6)Using remote, press DVD 7) Using the remote, press DUBBING. The VHS should start to play and the DVD should start recording
When using this method, don't hit the RECORD button!
No,the DVD player build in tv can't record,only play DVD Disc only.Want to record personal VHS tapes only to DVD Discs,must have a seperate device unit VCR/DVD RECORDER device player not a device unit VCR/DVD PLAYER.Connected to the tv record VHS tapes to DVD Discs.
VCR's automatically detect what speed the present tape was recorded
at. It only gives you a choice of speeds when doing the
recording. If you are saying that it won't playback a tape
recorded in one of the slow speeds, it is most likely because VCR's
with more than two heads use different combinations of them in
different speeds and the ones used for slow speeds are maybe needing
cleaning. If this is the case, the vcr will seem to be playing
OK, but the video playback will be bad.
Hey do the tapes play at all? sometimes some tapes recorded
on other machines won't play on others. maybe you need to adjust the tracking on the VCR you are playing it on. If the tape
was recorded on a VCR that is misaligned it might not play back
on another VCR. Also the tape may have been recorded on a
super VHS VCR in et (extended definition) mode if so they won't play on just any VCR. If the picture looks scrambled like a
premium channel on analog cable then it's probably recorded in et.
and if its recorded on super VHS tape it may eject out of your VCR.
They don't make these S-VHS vcrs anymore but people still
have them around. There is also Digital VHS they're not
compatible with VHS either. A VHS recorded in et mode will
play on some more expensive vcrs it should say so on the box
or instructions.
VCR is set with blank tape..Bring up vcr control on TV with television set on Chanel #3, go to menu
Follows procedure for progamming date,time start,time finish,chanel and.speed and single recording.finally click on menu and turn vcr off. Vcr lights indicate set for taping,,.Does no start to tape at requested time and lights indication taping ready stays on ??????
There are no such adapters that would allow 8mm, Hi8 and Mini DV tapes to be played in a VHS VCR. Only the old VHS-C tapes can fit and play in an adapter.
There are several reasons why 8mm (or Hi8 and miniDV tapes) cannot be physically played in a VHS VCR:
1. 8mm (Hi8, miniDV) is a different format with different technical characteristics than VHS. These formats were never developed with the intention to be mechanically compatible with current VHS technology.
2. 8mm/Hi8 tapes are 8mm wide (miniDV is 6mm wide), while VHS tape is 1/2" wide, making it impossible for a VHS video head to read the taped information correctly.
3. 8mm/Hi8/miniDV tapes are recorded and played at different speeds than VHS, so even if the tapes could physically fit into a standard VHS VCR, the VCR still couldn't play back the tapes at their correct speeds.
4. 8mm/Hi8/minDV audio is recorded differently than VHS. 8mm/Hi8 audio is recorded in AFM HiFi mode, while miniDV audio is recording in 12-Bit or 16-Bit PCM digital audio format. So, even if the video could be played back in a VHS VCR, the audio could not be read properly.
5. 8mm/Hi8 video is of higher resolution than VHS and is recorded in a different bandwidth length (miniDV video is recorded digitally), so once again, a standard VCR still could not read the information correctly, even if the tape could fit into a VCR.
