Brother DCP 115C All-In-One InkJet Printer Logo
Posted on Dec 06, 2008
My friend have a Brother DCP 115 C. I have take scans. it is asking insert black cartidge. what i have to do? is it i have load the ink cartidge. She told me that it is not required any ink? what shall we do? pl. reply immediately. savita
Anonymous
Level 1:
  • Contributor 13 Answers
  • Posted on Dec 08, 2008
Anonymous
Contributor
Level 1:
Answers
13
Questions
0
Helped
18331
Points
52
Try this, take out the black ink bottle,
clean between the sensors
"a grove in the machine at the front,where a slot on the bottle goes"
Clean with a cotton bud a small amount of bleach with water, or methylated spirits will do, also clean both sides of the slot on the bottle, then replace.
grandpaben
On Brother DCP-135C - if I only want to print black, do I need to replace the other cartidges?
It appears that one can purchase the black cartridge separately from the colour cartridges. But your Brother machine is designed to stop ALL printing operations when any of the ink cartridges are empty. In that case you would need to replace all ink cartridges that are empty in order to resume printing.
Brother dcp 130 keeps saying no black ink even though i,m after installing two new cartidges
make certain that contacts on new cartridge and on printer are clean so computer can read replacement cartridge.good luck
1helpful
The black ink doesn't print. We have brother cartridges in our printer DCP 385C, and until recently it always told us when ink was running out. now it doesn't print the black ink at all and it doesn't tell...
Make sure the protective tape covering the new cartridge has been COMPLETELY removed then reinsert. Your printer should tell you that a new cartridge is inserted and ask to print a test page, align etc. Otherwise your cartridge may have a faulty chip which simply wont read.
In which case you need to return it and get a replacement.
HOW DO I PRINT WITH BLACK INK ONLY
Hi there
No sorry it will not work with just the 1 ink it have to have all inks or printer not work
I only want to print black and white and not use
You can't.The printer needs all ink cartridge to initialized.
1helpful
Refilled black cartridge put back but dcp115 tells me to reinstal
there is a chip inside the cartridge that the printer firmware now failed to detect it. It is usually happen with refilled cartridge.
Try to find in the web "DCP 115 Reseter Software"
You can try Printer Resetter Software before you replace with the new original one (its the last option)
2answers
Norman Weimar
Norman Weimar
k24674
