I gave my phone to nokia care .at the time when i gave it ,its keys were working properly but when they returned it its keys are not working and im not able to switch on the mob.is there any solution for this
Why you had given to Nokia Care, What was the problem which take you to repair center.you should explain first.Hy, Chandraka, first thing make sure if your device is charging, if charge that means your device is working there is problem with keypad belt (which you need to change), so second you should not take your device in prior condition then before with Nokia Care, i think you should give responsibilty of this to Nokia Care.
SOURCE: Sony Ericssion K790i Keypad is not working properly
Keypad problems occur mostly from dust accumulation, if you know how to dismantle the phone use a blower to dust the keypad, or give it to an authorized service center.
SOURCE: my nokia3230 keypad is notworking properly
give it once service center or restore your cellular
SOURCE: My N72 keypad is not working properly
Hud have removed the battery immediately and use a hair dryer to blow out all the water traces from inside the phone. Some keys may have got water logged and need a change.
SOURCE: I HAVE A NOKIA 5130 C2 PHONE. HERE THERE IS A COMPLAINT IS THAT K
Hello. This is a common issue with keypads when the unit starts ageing. The flex cable needs replacement. Check the following and look up your model.
http://www.thefind.com/electronics/info-keypad-flex-cable
It is pretty straight forward to replace one the phone is dismantled.
