I too have the seven flashing amber lights . and have cleaned the print head .. and have gone thru holding the resume button and the power button and still cannot get the amber light to stop flashing
Probably your waste ink counter. Should be cleaned or replaced before resetting
but usually you can get away with resetting once. 1. Start with printer
OFF 2. Hold down RESUME and then hold down POWER 3. Release RESUME 4.
press RESUME twice, then release POWER 5. let green light blink until
printhead has finished moving. 6. Select functions below with RESUME, execute
with POWER
0 presses - green light - Test Print 1 press - orange light - EEPROM info print 2 presses - green light -
EEPROM initialise 3 presses - orange light - reset waste ink counter.
Canon PIXMA IP2000
You may RESET the printer code first if you like or do it after you clean the pad In some cases you may need to REMOVE THE PRINT HEAD FIRST or the reset code will not work. This was true of the S900 and i960 so, remove the print head first before doing this reset. This is the correct code for the S and I (like i960) series of printers. (M series below this) 1) Power off printer 2) Hold RESUME button then press and hold POWER. (The beeper MAY sound once, or may not depending on your model.) 3) Hold POWER and Release RESUME. 4) Press RESUME twice then release both POWER and RESUME buttons. 5) When the indicator lights steady, press RESUME 4 times (for the S900, 3 times for the 8200 apparently). 6) Press power to set data. 7) Print away! For other codes for other printers and more info go here to this big forum (but try the above first) Fix Your Own Printer Generally many of Canon's models use exactly this same code, the i models use the same code, all the s models use the same code.
5 flashes indicates a faulty printhead or possibly a problem with the p/head contacts. Try removing the head which is easier if you take the cartridges out first(no tools required) and re-seat it having checked the contacts for dirt.
If that doesn't work it may be that the waste ink tank is full. Try this ...
Canon S9000, S300, S400, i550, i560, i850, i860, i865, i9100, i9950, PIXMA iP3000 above, 1. Turn off printer 2. Hold down Resume button and press Power button. 3. Keep holding down Power button and let Resume button go. 4. Press Resume button 2 times then let BOTH buttons go. 5. Green lights will flash and then stop blinking. 6. When green lights are solid, press the Resume button 4 times. 7. Press the Power button and the printer should turn off, if not, press the Power button once more. 8. Your printer should respond as normal.
try the following
1. Start with printer OFF 2. Hold down RESUME and then press and hold down POWER Button. 3. Release the RESUME but continue to hold down the power button 4. Press the RESUME twice, then release POWER button.
Now you have put the printer in Service Mode so it will accept Service commands. Here is the list of Service commands;
A. Press the Resume button once = Print Service test print B. Press the Resume button twice = Print EEprom data sheet C. Press the Resume button Three = Initialize the EEprom D. Press the Resume button Four = Clean Waste INk Counter E. Press the Resume button Five = Change Destination settings F. Press the Resume button Six = Head Refreshing (Cleaning) G. Press the Resume buttom Seven, Eight, Nine, = Not used H. Press the Resume button Ten = Return to selection Menu
With the printer plugged in and powered off, press and hold the Resume/Cancel button, then press and hold the Power button. Do not release the buttons. The LED light should be green to indicate that a function is selectable
While holding the Power button, release the Resume/Cancel button, do not release the Power button
While holding the Power button, press the Resume/Cancel button 2 times, and then release both the Power and Resume/Cancel buttons. Each time the Resume/Cancel button is pressed, the LED lights alternately in orange and green, starting with orange.
When the LED light is green, press the Resume/Cancel button 4 times. Each time the Resume/Cancel button is pressed, the LED lights alternately in orange and green, starting with orange.
Press the Power button. The LED lights in green, and the reset is performed. When the operation completes, the printer returns to the menu selection mode automatically
The Power Light Flashes Orange - Error Codes
When
an error occurs, the power light flashes orange. The number of orange
flashes followed by a long green flash indicates the cause of the
problem. Two orange flashes:Out of paper, paper jam, or paper feed error
If
no paper is loaded in the auto sheet feeder, or if the paper is not
loaded correctly, set the paper correctly and press the Resume button
on the printer to continue printing. Three orange flashes: Paper jam
If paper has jammed in the printer, carefully remove the jam and press the Resume button to continue printing. Four orange flashes: A tank inside the BJ cartridge (print head) is out of ink
Replace the empty BJ tank and press the Resume button to continue printing. Five orange flashes: BJ cartridge is not installed properly
Remove
and reseat the cartridge correctly. Make sure the orange protective cap
and tape have been removed. Make sure the blue locking lever is locked
down securely. Six orange flashes: BJ cartridge (printhead) is not installed
Remove
down securely. Seven orange flashes: BJ cartridge (printhead) is defective
Remove
the BJ cartridge and check that the contacts on the cartridge and
cartridge holder are clean. Make sure the orange protective cap and
tape have been removed and reinstall the cartridge. If the error occurs
again after you resume operation, you may need to replace the BJ
cartridge. Eight orange flashes: Waste ink absorber almost full
The
printer has a built-in waste ink absorber to hold the ink that is
consumed during print head cleaning. This error indicates that the
waste ink absorber is nearly full. Press the Resume button to skip the
error so you can continue printing. The POWER light flashes orange and green alternately: Service error
A
service error means the printer requires the attention of a qualified
technician. Count the number of flashes. (You may be asked this
information.)
Operator error. Press printer's RESUME button. If this doesn't clear the error, cancel printing and turn the printer off and then back on.
When press Resume button, ip3000 not responed(not print)
I have similar problem. I found this solution that may help you. My problem insists tho.
If that doesn't work it may be that the waste ink tank is full. Try this ... Canon S9000, S300, S400, i550, i560, i850, i860, i865, i9100, i9950, PIXMA iP3000 above, 1. Turn off printer 2. Hold down Resume button and press Power button. 3. Keep holding down Power button and let Resume button go. 4. Press Resume button 2 times then let BOTH buttons go. 5. Green lights will flash and then stop blinking. 6. When green lights are solid, press the Resume button 4 times. 7. Press the Power button and the printer should turn off, if not, press the Power button once more. 8. Your printer should respond as normal.
