Flooding carb upon cold choked start...shutting down motor
SOURCE: try to start mower and turns over but wont start
Does it continue to run after you start it by pouring gas into the carburetor or does it die again?
If it continues to run, it sounds like your choke is not working. Probably disconnected -- check linkage.
SOURCE: i have a 16 hp kohler command engine on my scotts
if it has a electric fuel pump it may be malfuntioning,, hope this help you,, good luck
SOURCE: Why does my mower shut off after I turn the choke off?
It sounds like you took the carb off the engine and did not replace the gasket or tore the gasket and it is sucking too much air. Also check to see if the carb and bracket ( if it has one ) are on straight.
SOURCE: Walbro Carburetor on Briggs & Stratton Model 28R707
If the float don't float, the needle valve stays open and gas runs into crankcase.
If float floats (has no gas inside) then the needlel is probably worn and needs replacement.
SOURCE: Craftsman riding mower floods after a few seconds
FYI...just thought I'd give a little back...
had exactly the same mower/plow w/ same issue !
mine is an older L-head from pre-1998...used....
19.5hp 3 screw type diaphram fuel pump carb...
the pic's and how to assemble... I will send if,
you email me... Instructions do not come from
B&S when you buy there part # 694056... = 10$
carb rebuild kit...they want to sell the manual too !!!
sku# 0 24847 26246 9 ...shame on them !
they are selling manual # 27xxxx for 20$...
to tell you what to do ! ....%$#-THEM !!!
I made a pdf...with before and after pic's of
how to rebuild this carb...it's quite unique in fuel pump design and simplified governor operation...
running well this 19.5 twin - fan cooled...is like a 25HP !
the carb kit from B&S is generic...w/extra parts...
I have pic's of the actual ones used/needed for this
carb... Main jet is mis-labeled...it's a bowl vent !
There are no jet's to adjust on this carb...
only adjust is idle speed post the governor linkage !
also shown functioning in my .pdf...
hit my mail ..... driscoll_at_pzdi_"dot"_com
or visit www _ pzdi _ com
248-390-3541
