Because of the power interuption the recovery partition has been corrupted, the hard drive will need to be formatted to use the recovery discs. Go to www.acer.com contact customer support and the technical department for additional help, they have one of the best support programs available.
SOURCE: Acer Aspire 3693WMLi -Launch startup repair
It might also means that your hard drive is not working properly. My laptop's hard drive went out making the same blipping sound and white screen after that, this happens some times for over heating. Now if you get a error number let us know it might help
SOURCE: RESTORING WINDOWS/BOOT MANAGER
Sounds like you have Vista. Here is a link on creating a Vista recovery cd:
http://neosmart.net/blog/2008/windows-vista-recovery-disc-download/
This link is a how to document on repairing the BootLoader:
http://neosmart.net/wiki/display/EBCD/Recovering+the+Vista+Bootloader+with+EasyBCD
You may have to copy and paste the link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
SOURCE: Windows Error Recovery
Using the Windows installation cd. Boot the system with the CD in the drive. When given the option select the repair option. This should correct the issue. Hope this helps & please remember to rate my answer. Thanks.
SOURCE: windows boot manager for TOSHIBA PRO L300
You will need an original windows installation disc and not a recovery disc. If you do not have one, then you have the option of taking to a shop that does and have them run the repair utility. Or, if you can find someone who has burned a copy of the windows ultimate boot disc, that will also help in repairing the boot manager and files.
SOURCE: status 0xc000000f Window failed to start
You are facing this problem because of some software update which you might of done in recent times. So the boot loader is failing with error code 0xc000000f.
Download the Repair for boot loader from the link below:
http://neosmart.net/dl.php?id=1
Run the software it will rectify any errors caused due to any software update.
This will solve your problem.
Hope this helps.
Shane
here are the additional details that seem to have not posted the first time...............I was in the process of restoring my laptop, and it lost power and has been in this loop since....the recovery CDs no longer work, is there anything that can be done or do I have to buy a new hard drive? and will a HD do the trick?
I downloaded the windows 7 repair disc and ran it 4 times or so says it is fixed, but I still get the same thing.....when I tried to do the command prompt.....it said boot.exe was not found
