Which connection type are you trying to use (VGA, HDMI, etc). It would help to know what kind of computer you are using and whether you are using the projector as the only display or trying to do multiple displays.</br>
If using a laptop then check and see if you have a key to switch displays. It will usually be one of the function keys (F4, F5, etc) and will most likely be a secondary action of the key requiring you to hold down your FN key then push the function key. This will switch between your laptop's outputs.</br>
If using a desktop you need to go to your display properties. Win7 right click the desktop and go to Screen Resolution. You need to make sure that the Multiple Displays setting is set to Duplicate These Displays or Extend These Displays to make sure that the display adapter is sending a signal to the projector.
