I have a damaged microphone diode, capacitor or resistor on the PCB. I do not know what it is exactly. I have isolated it because when I lightly tap it with a rubber tipped pick it transmits audio for a moment. I tapped everything else on the pcb just to be sure it wasn't vibrations moving elsewhere on the board. It is a silver tube with wires and a light blue clear rubber sheath. On the side of the silver face is stamped 12.000. Does anyone know what this part is or has a schematic that points to what it is so I can order and replace this part?
SOURCE: Do I need a driver for plantronics USB DSP v4 audio interface
Yes you would need a driver for your Platronics headset if you intend to connect it to your PC
Could you please describe the model of your plantronic headset so that i can get the required drivers for you.
Thanks.
SOURCE: How do I replace the ear cushions for a Plantronics DSP 400?
There are some small silver inserts on the side of each earpiece. You can pry them off (gently) starting under the cushion and working your way around.
You can then remove the old cushions and put in the replacements and snap these silver retainer inserts back on.
You can get replacement cushions online for about $16.
SOURCE: Where can I download a driver for my plantronics
LJBENGE try to visit this site http://www.microsoft.com/windows/compatibility/windows-vista/Search.aspx?type=Hardware&s=Plantronics%20DSP%20500%20headset and try the drivers for vista... good luck!
Testimonial: "I did that before contacting you and they state Windows driver is compatible but Vista asks for driver. Headset older"
SOURCE: Trying to connect Plantronic 220
1.First switch on the bluetooth in mobile phone.Keep the headset switched off.
2.Now press the call button for 2 seconds if you are paring this headset for first time,If this head set is aired already with another mobile press for 8 seconds until the headset status indicator
begins to flash blue then red
3.Now search the bluetooth by your mobile device.It detects and you can pair it
Thank You
