I have a problem with this drill where the bit i insert in the chuck locates nice and tight. as per normal. but if i grip the end of the bit i can move it about by approximately half an inch. like in any direction. and if i try to drill masonary with it the bit tends to wander off to one side or another. any ideas guys? cheers
SOURCE: Agitator halves are not in sync
yes it is replce them usually 4 and you'll be as good as new
SOURCE: how do i insert a
Sorry but I think you need to repost this elswhere as this is the WASHING MACHINE Forum rather than the DRILLING MACHINE one ;-0)
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
SOURCE: Hi, I tried inserting a
Had the same problem with our Bosch, cap would not even turn!
Suggestions-
pour anticalc/limescale fluid into any gap there is around the cap. Empty the machine and you can switch it off providing the door is open! Then pour the contents of at least 2 sachets of proprietary anticalc powder/liquid into the drum direct together with a kettle full of boiling water. Leave overnight at the very least. The following day run just a spin cycle as then there will be no water diluting the mix. This mix will go through the filter and motor and is likely to help release the filter/cap. If you feel like it, do the overnight again. If nothing else it will ensure that the heater element is clean!
I had to spend a couple of hours gently turning the cap back and forth until it finally released its hold- but the filter did not remain attached to the cap by its rubber ring. More patience, anticalc fluid and all was revealed!
I now run an anticalc clean regularly............which reminds me..............!
John C
