If i played a music on my laptop or even played a video its just like i listened to a pirated cd's
You should try updating your audio driver.
Also,
Update your Adobe flash player software to the latest version:
http://get.adobe.com/flashplayer/
If that doesn't fix it you might have some viruses and malware.
Start
your PC and press F8 several times until the boot menu comes up. Then
select "Safe Mode with Networking". Now get some or ALL of the FREE
programs below.
Download, Install and Run Malwarebytes Anti-Malware:
http://majorgeeks.com/download.php?det=5756
When Installing choose the non-pro version.
Download, Unzip, Install and Run TDSSKiller:
http://majorgeeks.com/Kaspersky_TDSSKiller_d6895.html
Download, Install and Run Super Anti-Spyware:
http://majorgeeks.com/SUPERAntiSpyware_d5116.html
If you have an outdated Anti-virus program then Download, Install and Run Avira Anti-Virus:
http://majorgeeks.com/Avira_AntiVir_Personal_-_FREE_Antivirus_d955.html
Make sure to select ALL of the "threat categories" when you install or configure Avira...
You should be in pretty good shape if you run and install all of these programs.
SOURCE: Scratchy and distorted sound in media player
There are a few possible reasons for this.
1. Your drivers are bad, look for new updated drivers from vendor and from windows update.
2. Your system is under heavy load and has trouble playing sounds, you can try to close not needed programs from the taskamanager.
Also, download process explorer http://technet.microsoft.com/en-us/sysinternals/bb896653.aspx'
after extracting the program from the zipfile pay close atention to what is useing the CPU take note if INTERRUPTS / HARDWARE INTERRUPTS or DPC's / Deferrend Procure Calls are happening alot. This can be a sign of hardware problem or complex windows problem. In this case I would recommend reinstalling windows. If the problems continue it is most likely a hardware issue.
If INTERRUPTS and DPCs are normal between 0 and 50, for short perioids, can be higher, but if constant high values then this is a problem.
If those two are not a problem go thrue all applications and find out witch is eating all the cpu, when found try shuting the program down by pressing delete after selected on process manager.
If these dont solve the problem I'l type more later.
SOURCE: Distorted / skipping sounds from Acer laptop
Go to the sound icon which is at the right hand bottom corner on your task bar, explore properties cheack wheather voice supression is any thing else than 0.As well as check for enviroment.
SOURCE: Dell inspiron 6400 laptop not playing video CD and DVD
just install cyberlink power dvd then it will stgart playing all kind of video cds and dvds from dvd rom
