For a Chaintech 9BIA motherboard;
Motherboard chipset is an Intel 845,
http://en.wikipedia.org/wiki/List_of_intel_chipsets#Pentium_4_chipsets
http://www.firingsquad.com/hw/168/Chaintech_9BIA/PC133 (SDR Sdram at 133MegaHertz;
{Single Data Rate. The proper term, not just Sdram.
Double Data Rate Sdram is Sdram.
Double Data Rate 2 Sdram is Sdram.
Double Data Rate 3 Sdram is Sdram.
DDR Sdram, DDR2 Sdram, DDR3 Sdram.
Synchronous Dynamic Random Access Memory )
Low-Density, Unbuffered, Non-ECC, Cas Latency of 3
(Don't get some cr@p off of Ebay.
It's usually high-density, ECC, that was used by old server computers)
http://www.newegg.com/Product/Product.aspx?Item=N82E16820146305WHEW! Unless you just want to run 1GB of ram memory, I would toss that board! (Two 512MB sticks) ->
-> Need two 1GB sticks of SDR Sdram at 133MHz
http://www.directron.com/ct128m72s4r75.html$400 smakeroos USD!!
Bah! That is just cra-zy!
Maximum TOTAL Amount is 2GigaByte. (2GB)
Maximum Amount for EACH ram memory slot is 1GB.
IF, you only have ONE ram memory module ('Stick'), it goes in Slot 1. (DIMM 1)
That is the ram memory slot closest to the processor socket.
The Processor reads ram memory Slot 1 first.
http://www.cpu-upgrade.com/mb-Chaintech/9BIA.html
Regards,
joecoolvette
Un register from what?
