Have tried default settings, doesnt work, serial no is 356383025846106, can supply pin and puk if required, [email protected]
You can do a master reset to your phone. This would restore your phone with default factory settings. You can get the master rest code for your Nokia 6600 from www.Theunlockspot.com at affordable cost.
SOURCE: My pin code is blocked. Need Puk code. Pls help
The PUK code is a code associated with the SIM card and not with the phone.
You have only two ways to get rid of the PUK code. Either you replace
the SIM card , or you call phone provider that issued the sim cadr (eg.
At&T, Virgin, Tmobile , Vodafone, Telecom etc.)
PUK means "personal unlocking key" .
The PUK code is asked if you enter a wrong pin 3 times.
You need to call the phone company that released the SIM card, they can retrieve the PUK code from a database for free.
In your case you need to contact your SIM card provider technical support to unlock the SIM.
The PIN and PUK are related to the SIM card, not to the phone.
If you replace the SIM card with a different one, then the phone will not ask for the PUK anymore.
SOURCE: Nokia 5300 Security Code problem
try 12345 if that dont work you will need to ring up nokia and tell them your imei no and they will provide you with a security code
SOURCE: I need code puk nokia 2720 plisss!!!
To get a PUK code you need to call your Mobile service provider. They will provide you the PUK code for creating another PIN.
Note: there is no other way to get a PUK.
Thank you for choosing Fixya
SOURCE: nokia 6600 security unlock code reset.
get free security reset code and then reset your code get it here
http://www.unlock-free.com/
need another solution, doing a master reset means i loose too much stored data etc (according to nokia manual) and nokia manual for 6600 slide does not give instructions on retrieving security code so still need help! thanks all
