Hewlett?PackardHP Notebook PCs - Troubleshooting LED Blink Codes or Beep Codes During Startup or Boot ... HP Pavilion and Compaq Presario notebook computers built in 2009 or later use blinking LEDS to identify ... Press the power button to turn on the computer, and look for blinking LED lights on the keyboard. ... Continuous blink.Missing: green nc6320
This document pertains to HP and Compaq notebook computers. .... light next to thepower socket or the light on the AC power adapter and note its condition: off, blinking, or constantly on. ... Battery power LED off, and Caps Lock/Num Lock off.Missing: green nc6320
Hi, your remote has probably lost its coding. If you have the owners manual check page 65 learning additional remotes. If not do the following 1. Plug in the 6 pin hopped coded plug to control unit under drivers seat. 2. Press unlock button twice to disarm. 3. Press learn button on hopped coded plug. this erases all pre learnt codes. The led on dash should start blinking once per sec. 4. Press learn button on hopped coded plug again. The led on dash remains on for 4 sec. and then starts blinking faster. Ensure to do step 5 within 25 sec. 5. Press any button thrice on your remote that has a problem. 6. In response led on dash remains on for 4 sec and then blinks once per sec.This indicates that the remote has been learnt. Hope this helps.
Can you confirm if you are able to put the BTH220 headphones in pairing mode. Please try the following steps and see if works:
Make sure that the headphones are fully charged.
Switch off the headphones.
Put the headphones in pairing mode by pressing the MFB button (center) for 7-10 secs till you see the red and blue LED blinking alternatively. Please do not leave the button as soon as blue LED appears.
Follow the operating instruction of your Bluetooth device to start the pairing process.
Hold down the power button until the computer shuts off. The press the button to restart and see what happens. There are several different ways to startup. immediately upon hearing the boot tone, press and hold the shift key to boot in safemode. If this fails as well, then you will need to boot with the install CD. This is done by immediately pressing holding the C key upon powerup
check duplex unit fixed properly,Do cold restart( hold the go button switch on the printer after all LED are once blink release the button ensure that don"t hold the button more than 15 sec)..Check the drivers..
Are they Long Beeps? Does the RED led light on the front show up? If there is no RED led light blinking, then the problem is your RAM. If there IS a RED led Light showing up, then the problem is your Power Supply.
This is just an off-chance thing. The three lights could indicate a failed or badly seated memory chip.
Turn the Mac off and remove the side. Remove the perspex panel and then remove the grey plastic panel containing the 2 large fans (it just pulls out towards you).
You now have access to the RAM sticks. Use the illustrations on the inside of the Aluminium door to identify the sticks and so that you can remove and re-seat them. Refit the fans and the perspex panel and see if the mac will start up. If not, you may have to try extra RAM (depending on how much you have installed). These macs have their RAM installed in matching pairs so if you have only 2 stick in your Mac then you need to get 2 more in order to eliminate the first 2.
Report back if that helps.
Sounds like a communication error somewhere between the printer and your hardware. You might need to update the driver. Go to the manufacture's website and put the model number of your printer in to get the latest driver. There might also be a driver specifically for your Mac there.
