Question about Motorola Mobility MD761 Cordless Phone
Registering handset problem
After having two handsets registered and starting the answering machine, all handsets went "out of range" and I am unable to register handsets again. Any suggestions?
  • joyeuse Apr 30, 2008
    how to register my motorola hadsets MD70. They are out of range. Where is located the page botton?
Worked for us AFTER plugging/unplugging the base unit. thank you!
Posted on Apr 12, 2008
How to register my motorola MD70 handsets? Both of them went out of range... Where is located the page button?
Posted on Apr 30, 2008
I have been having this problem myself for a while now and couldn't find the manual. I tried your advice and it worked right away! Thanks a bunch!!
Posted on Mar 06, 2008
Heh.... I'm having the same exact problem. Except I didn't use the answering machine. I had the one handset off the charger for a good long while, and I went to charge it up -- both handsets turned "out of range."
Posted on Mar 09, 2007
  • Anonymous Mar 09, 2007
    OK, we fixed it. All we did was press and hold the flash key. Searching..... Searching.... and it finally worked.
6ya staff
SOURCE:
DS6321 out of range, no power at base
This sounds like a registration problem, the handset(s)
and the base have lost identification with each other.
I. To address this, first de-register the handset(s) ---
do this procedure for each handset:
0. Start by taking off the battery compartment cover....
1. press [menu]
2. scroll up/down to "Settings"
3. enter * 7 8 9 0 #
4. scroll down to "next page", press [select]
5. scroll down to "Register Clear?", press [select]
6. display asks "Confirm?" or "Register Clear??", press [select]
7. display reads "Ok" and chirps, press [ off ]
8. UNPLUG THE HANDSET BATTERY (why the cover was off)
9. Wait ~30 seconds, re-connect the battery & replace the cover
10. display reads "Not Registered" ===============================
II. To register the handset to the base:
1. press [Find Handset] on the base and hold for
~4 sec until the "In Use" lamp lights.
2. press # on the handset and set the handset into
the handset cradle on the base
3. within 30 seconds or so, the handset will either
chirp and display "Handset Registered", then
"Handset #1" or it will say "Registration Failed".
NOTE: the battery must be well charged prior to the
registration process, a weak battery may cause a
"Registration Failed". Charge the battery for a few
hours and try the registration ( II ) again.
NOTE: the base can only handle 5 handsets and will
increment the number of each handset registered
until "Handset #5" has appeared, even if some of
the handsets are lost/not in use. Trying to register
more than 5 handsets will result in "Registration Failed."
III. To clear the base of all handset registrations and
be able to start registering again at Handset #1:
1. press [Find Handset] on the base and hold past ~4 sec when the "In Use" lamp lights, at
about 10 secs the "In Use" lamp will begin to
blink.
2. release the [Find Handset] button momentarily,
then briefly press it again. After a moment,
all handsets that were registered to the base
(if any) will display "Not Registered" and be
ready for fresh registration
3. for multiple handsets, return to II. above and
register each handset in turn.
Good luck !!
May 02, 2016 | Vtech Lands Phones
Can not get the second handset to register to the base
This is the registration procedure
Step 1: press MENU-6 and select 3 “SET BASE”
Step 2: press the REG key on the master base
Step3: press register to finish the registration procedure.
• After the registration complete, handset 11 and handset 21 can
2-WAY intercom with each other
If issue persists reset the unit start registration by using 2nd unit that currently unable to register. if issue continues please inform for further troubleshooting
Good Luck
Jan 01, 2008 | EnGenius SN 920 Ultra Cordless Phone
Can not register handset
The handset must be de-registered before it can be registered.
Try this:
1. To de-register the handset from another base:
When the orphaned handset says "Connecting..." or
"Out of Range..."
enter *331734 [menu]
and it will soon beep and display "Not registered"
2. To register the new handset to your base:
press the "Handset Locator" button on the base and hold
it until the "in use" light comes on ( ~ 4 seconds ),
then release the button and set the new handset into
the base phone cradle. After ~ 30 seconds it will beep
and display "Handset #" (next in sequence).
3: Note: the base handles a maximum of 12 handsets.
If your system was fully populated ( ie, a handset is
already # 12 ) you will have to clear all the handsets
from the base and re-register them all in sequence.
( it is the only way to 'rescue' the places occupied
by the lost handsets ).
To clear the base of all registrations:
1. Press and hold the the "Handset Locator" button
until the "in use" light lights and then starts to blink
( ~ 10 seconds ), release the button --
then press it again briefly while the "in use" light
is still blinking.
2. The base will beep and all handsets that were registered
3. Follow the instructions above for each handset
in turn to re-register them:
press "Handset Locator" ~ 4sec ( in-use light on ),
set handset into the base cradle, etc.
The manual is available from: www.manualslib.com
but does not fully describe these procedures.
Good luck !
Nov 22, 2015 | Vtech AT&T CL83213 2 handset cordless...
My Uniden 1560-3 has out of range on all handsets but one. I only have a dial tone on one handset. Please advise how I can correct this problem
Reset the hand sets that are out of range by doing the following:
1) Press and hold END and # for at least five seconds.
2) Move the cursor to select Base Unavailable and then press Menu/Select.
3) Select the base which you want to de-register from, and then press Menu/Select. Base Unavailable appears.
4) Move the cursor to select Yes, and then press Menu/Select. You hear a confirmation tone,
(For DCX150 handsets)
5) Place the handset in the base cradle for about thirty seconds. Handset Registering will appear in the LCD.
6) When the handset has registered to the base, the LCD will display Registration complete then show the handset
ID number.
If the display shows Registration failed, repeat the process again.
(For DCX200 or DCX300 handsets)
5)Disconnect the base AC adapter. Then press and hold find while you reconnect the adapter. Keep holding
find until the charge LED starts to blink.
6)When charged, registered handsets display a handset ID number. Handsets that have not been registered display:
7) On the handset, press and hold # until the handset beeps and displays Handset Registering.
8) When the handset has registered to the base, the LCD will display Registration complete then show the handset
ID number.
User Manual Available Here
Jun 16, 2011 | Uniden Cordless Phone
Handset No2 displays out of range message
Please check that you have correctly registered the second handset to the base. It may be necessary to de-register the second handset and then re-register it. "Out of range" just means the second handset is not within range of the base phone it was registered to.
Mar 08, 2009 | Uniden TRU8885-2 Cordless Phone
Can I use handsets from another DCT 748 unit to expand my DCT 748
Short answer:
No. This model of phone can only support 4 handsets. If you need more than that, you will need to have a second base unit.
Detailed answer:
One of my handsets went bad, and I just bought complete DCT748-4 package from a seller on eBay for a very good price. This set was used, but in very good condition. I didn't need the whole set - just one handset - but like I said, it was a good price. Anyway, I began by telling my old base unit to de-register handset #2 (the failed unit). However, I then found that I could not register the "new" handset with my old base unit because it was already registered to the "new" base unit. So, I first had to apply power to the "new" base unit and de-register the handsets. Then, I placed one of the "new" handsets onto my old base unit, and it said "Handset Registering ..." and registered just fine. Just for the fun of it, I placed one of the other spare handsets into my old base unit. It said "Hanset Registering ..." but then it beeped and said "Registration Failed." This is because I already had 4 handsets registered to my base, and the base can not handle a fifth handset.
Feb 15, 2009 | Uniden DCT-748-4 Telephone
Uniden Cordless Phone Model DSS7855. frequently fails to connect to an incoming call, with 'out of range' indication. The phone is less than 1 meter from the base station.
The handset/base keeps a record of who it’s registered to. The base also keeps a record of how many handsets are registered to it.
Using the de-register function on the handset deletes the handset from the base (decrements the count) and deletes the base info from the handset. All this requires that the base and handset can communicate with each other.
To remove the base data from a handset when out of range of the base, press and hold the ‘end’ button and the ‘#’ button simultaneously until the phone beeps. It will now be de-registered from the base.
However, the base will still have this handset in it’s record.
To de-register all handsets from the base, remove power and the base handset. Press and hold the ‘flash/find hs’ button while applying power. Wait for the beep and release the button. The charge light will now flash. Sit any handset in the cradle. When the flashing stops, all handsets are inhibited from connecting.
However, the handset still appears to be connected to the base unit. Pressing talk will give an ‘Unable to connect’ message. To re-register the handsets to the base, you have to de-register the handset first with the two button method.
Of interest, pressing ‘*’ and ‘#’ on the handset while reconnecting the battery is suppose to reset the handset. Doing the same on the base unit puts you in some sort of diagnostic mode. Press speaker to exit.
Aug 21, 2008 | Lands Phones
Will not connect - "Out of Range"
One idea is that the handset is not registered with the base unit. When the phone is new, you must register the handset with the base prior to use. Is this, by any chance, a second handset that you recently acquired? If so, you should be able to set it in the cradle for the base unit for a few seconds, and after that, it should be fine.
Aug 11, 2008 | Uniden TRU8885 Digital Answering Machine
UNIDEN 5.8 GHZ CORDLESS PHONES
Registering Handsets to the Base
Whichever handset you choose to charge in the base is automatically
registered to the base. Any additional handsets must also be registered to
the base before you can use them.
Be sure both handsets are fully charged.
One at a time, place each handset in the base. The charge/in use LED on
the base begins to flash, indicating the base is registering the handset.
Wait for at least five seconds, then pick up the handset and press
[talk/flash]. If the display shows TALK, the handset is registered. If not,
place the handset in the base to try again.
Press [end] and continue with the next handset.
Note:
Once both handsets are registered, it doesn’t matter which
handset is placed in the base or the charger.
When you charge the handsets, Caller
ID summary screen and the name of
the handset appears.
This can be find from uniden website.
http://www.uniden.com/pdf/DXAI4588-2om.pdf
Oct 17, 2007 | Uniden TRU8885-3HS Digital Cordless Phone
Registering a new phone
With a little searching I was not able to confirm this phone could handle more than one cordless handset. Are you replacing a defective handset or trying to add a second. If adding, do you know if it can handle the second unit (is it advertised on the box, in the user guide, etc?) If replacing, you most likely have to de-register the old handset on the base unit before you can register a new one. If you are adding, try de-registering the working handset anyway and registering the new one. If the new one registers and you cannot re-register the once working phone you will know either the system cannot handle two phones or (if the new one will not register but you can again re-register the original) that the new handset has a problem and should be returned.
Jul 10, 2007 | Uniden Cordless Phone
Motorola Mobility MD761 Cordless Phone Logo
610 people viewed this question
Top Motorola Mobility Lands Phones Experts
John Donghia Jr.
John Donghia Jr.
Clyde Hanson
Are you a Motorola Mobility Lands Phone Expert? Answer questions, earn points and help others
