The cooler only leaks when running. the Honeycomb Water Curtain is getting water. and I have sprayed the inside of the water basin with a sealant. I am still getting a leak at the seam by the left front wheel/castor as you are facing the machine. any suggestions as to how to fix the liak or where it is comming from?
SOURCE: we bought a Bonaire cooling system at yard sale,
I take it this is a window Unit , the water is coming in the room because the Unit has to be pitched about 1/2 into the back ( outside ) or the drain line is clogged ( dirt) stopping water from flowing to condenser ( that cools the coil)
The water is condensation from warm air hitting the cold coil .
SOURCE: dishwasher leaking
just an idea...if i'm understanding you correctly,could the door seal be creased there or folded over by use and age to permit this to happen? cause you said nothing is missing
SOURCE: Kenmore washing machine is leaking water from the bottom left fro
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
See the section for the basket and tub assembly's
I'd pull the cabinet in order to get to the hoses going to and from the pump first.
See the following:
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131
If the hoses are fine, I'd also check the gaskets at the bottom of the tub.
If you're reasonably mechanically inclined, these are easy fixes.
If you have to get to the gaskets at the bottom of the tub, see the following for how to remove the agitators, pump, motor, transmission, spin tube and basket.
(It sounds a bit complicated but it's not really that difficult.)
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
You don't have to buy a special spanner wrench to remove the spanner nut. I've used a short 10" pipe wrench hooked over one of the tabs on the spanner nut, tap the handle with a hammer and it should loosen.
Also, don't directly hit the drive block with a hammer. Use a short piece of wood under the drive block and tap up on the wood.
As an aside, see the following Whirlpool Service Manual for top load direct drive washers.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
Depending on the problem (hoses or gasket) it's certainly less expensive than calling in a repair person.
SOURCE: leaking from inside door
It's located here, just download and save.
http://miele.com/manuals/before_download.asp?id=164&bhcp=1
SOURCE: NewAir AF-350 is blowing water
water normally condenses in the evaporator .. this runs down to a pan that drains to the outside section of the air conditioner .. there it it used to help cool the condenser and overflow runs out a drain in the back ... your unit is not draining the water properly to the back section .. that is usually caused by the air conditioner being being mounted with its top tilted toward the inside ... it should be level or slightly tilted toward outside for proper drainage ... its also possible that paper or other debree has clogged the drains inside the unit from the front section going to the back section ..
