How to find out the computer access code?
To create a new access code
Note: You will need to be at the host PC to perform this function because you will not be able to log in to your host PC without knowing the Access Code for that PC.
Thats if you want to change the access code but if you are simply looking for your access code you need to get in touch with your group.
Code Access Security is a new concept brought in by the .NET framework. Code access security essentially involves granting permissions to an assembly. Code access security uses the location of assembly and other information about the identity of code as a primary factor in determining permissions to be granted to the assembly. This information about the identity of an assembly is called evidence.
Once loaded in runtime, the code starts executing in the restricted environment depending upon permissions granted to it. If the code is not trusted enough to run or runs but performs an action for which it has no permissions, then a security exception is thrown.
The code access security system means we can stop running of malicious code and also restrict the code to run in a restricted environment where we are sure that it won’t do any damage to the resources. Let us now see few cases where code access security becomes
crucial.
Suppose an organisation is working with some extremely important data, we would use a code access security system to state which code is allowed to access the database and which is not. Similarly if we run an application from a network drive and it tries to access the file on a local drive an exception must be thrown. This can be done using a code access security system.
It is important to know that code access security protects resources like local disk, network, user interface from malicious code. It is not a tool for protecting software from users.
Code access security works on the basis of Code Groups and Permissions.
SOURCE: what is Computer Access Code
u mean when you first turn it on it asks for a PW,
unplug it (necessary)
then
take off left side cover (when looking at front) (if you have to take out more than 2 screws your doing it wrong)
and pop out the small silver watch battery with a flat screwdriver(push tab) for a few minutes
put everything back
if you dont see it or don't know what your doing leave it alone or you'll screw something up
how to find out the computer access code?
HI,
I read your problem, and wanted to clarify:
Are you trying to access the BIOS settings, when you first turn on your PC?
Regards,
JT
