If your ARCHOS does not respond correctly or does not start properly, you can try to remedy this situation with a system recovery. Be very careful with this as there are options to erase all the data on your device.
20.3.1.
To enter into the Recovery screen - Turn off the device and wait 10 seconds.
- Press and hold the volume
+ button while powering on the device.
- Keep the volume
+ pressed until the Recovery mode starts (white screen).
- To move from one Go to
this web page to see the latest on-line version of this manual. Go to
this web page to see the latest on-line version of this manual.option to another, use the volume buttons. To select an option, press the ON/OFF button. Go to
20.3.2.
Recovery mode options
No: Cancels the system recovery.
Update firmware: Allows you to connect your device to a computer in order to copy the latest .AOS file (operating system) to your device and then install it.
Repair System: Attempts to repair the file structure on the internal memory. This does not erase any data.
No: Return to main recovery screen.
Force Touchscreen Calibration: Select this, set your device down, start the calibration, and don't touch it. It will re-calibrate the screen. After the calibration is complete, select
No to leave the recovery screen.
Check Disk: Check and repair the system partition if damaged.
Start USB MSC: Allows you to connect your device to a PC to access the internal memory.
Format System: Formats the internal memory. All data (music, photos, videos, etc.), applications and settings are erased.
HOPE IT HELPS AND GOD BLESS!!!
it just goes straight on to the recovery screen and fails on any of the options every time. it will not come up on my computer when i plug it in aswell so it wont let me do it that way
