Heating & Cooling Logo
A
Anonymous Posted on Jun 26, 2012
How to unlock gree ac remote - Heating & Cooling
Julie Thod?
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Dec 23, 2013
Julie Thod?
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
11559
Points
10
To lock and unlock Gree remote control press '+' & '-' simultaniously.
Anonymous
Level 1:
New Friend:
  • Posted on Jul 27, 2013
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
11559
Points
Hi
i have gree ac today my remote have lock how can open the lock
jack morton
Level 3:
Master:
  • Heating & Co... Master 523 Answers
  • Posted on Aug 24, 2017
jack morton
Level 3:
Master:
Answers
523
Questions
14
Helped
255675
Points
1290
Press the up and down buttons simultaneously and hold until the lock icon shows unlocked. Thus is a child lock feature. Manual is available online for free.
1 Related Answer
Anonymous
  • 70 Answers
  • Posted on Jan 04, 2009
SOURCE: AC remote not working
www.gree-ac.com this is gree website you will need a model and serial number from unit I would contact them to see who your local suppliers are or online order remote m# and s# would also help if available
H4 error code is shown on AC display what can i do to slove this problem
Full list of Gree Air Conditioner Mini Split Units Fault Codes. When error codes appear on the Gree air conditioner indoor display, this tells the user there is an issue with the Gree AC unit. The error code displayed will inform you of the issue or problem that is occurring with the air conditioner. Knowing what the error code means and its definition will help you to understand and troubleshoot the exact Gree air conditioner part that needs to be fixed, cleaned, repaired, or replaced. You can then clean, fix, or replace the Gree part yourself and save money. See below for all error codes that can occur on Gree Mini Split AC's.
Gree Mini Split Air Conditioner Error Codes - How To Fix
Gree Viero AC Mini Split PDF Owners and Troubleshooting Manual
GREE DUCTLESS AIR CONDITIONING & HEATING SYSTEM INSTALLATION MANUAL
Gree Mini Split Air Conditioner Part Names and Locations
INDOOR AND OUTDOOR UNIT
The Gree Air Conditioning Vireo System has onboard error code diagnostics. The outdoor unit will provide status indicators and the indoor wall unit and remote control will display error codes. The following is a summary of the codes with explanations...
GREE AC DIAGNOSTIC ERROR CODES
Gree Vireo Mini Split Air Conditioner Error Code F0
Refrigerant Leakage Protection
1) Refrigerant leak(s).
2) Indoor coil temperature sensor not calibrated.
3) Refrigerant flow is restricted (ex. valve, exv, debris)
Outdoor Unit Red Light Indicator - 9 flashes and 1 sec Off
Gree Vireo Mini Split Air Conditioner Error Code E1
System High Pressure
1) Over charged with refrigerant.
2) Blocked or dirty outdoor coil.
3) Extreme outdoor ambient conditions
Gree Vireo Mini Split Air Conditioner Error Code E2
Indoor Anti-Freeze Protection
1) Low return airflow.
2) Indoor fan speed is too low.
3) Indoor coil is blocked or dirty.
Outdoor Unit Yellow Light Indicator - 3 flashes and 1 sec Off
Gree Vireo Mini Split Air Conditioner Error Code E4
Compressor High Discharge Temperature Protection
Please refer to the malfunction analysis (discharge temperature, overload) in service manual.
Outdoor Unit Yellow Light Indicator - 7 flashes and 1 sec Off
Gree Vireo Mini Split Air Conditioner Error Code E5
Overcurrent Protection
1) Supply voltage is unstable.
2) Supply voltage is too low and system load is too high.
Outdoor Unit Yellow Light Indicator - 5 flashes and 1 sec Off
Gree Vireo Mini Split Air Conditioner Error Code E6
Communication Malfunction
1) Communication cable is wired incorrectly between indoor and outdoor units.
2) Indoor or Outdoor control board malfunction.
Outdoor Unit Yellow Light Indicator - Continuous On
Gree Vireo Mini Split Air Conditioner Error Code E8
High Temperature Resistant Protection
1) Incorrect refrigerant charge level.
2) Refrigerant metering device malfunction.
3) Compressor malfunction.
Outdoor Unit Yellow Light Indicator - 6 flashes and 1 sec Off
Gree Vireo Mini Split Air Conditioner Error Code EE
EEPROM Memory Malfunction
Control board malfunction.
Outdoor Unit Yellow Light Indicator - 11 flashes and 1 sec Off
Gree Vireo Mini Split Air Conditioner Error Code C5
System Configuration Malfunction
1) No jumper cap inserted on the control board.
2) Incorrect or damaged jumper cap on control board.
3) Indoor and outdoor units are not compatible.
Gree Vireo Mini Split Air Conditioner Error Code Fo
Pump Down or Gathering Refrigerant Status
Optional Service Mode
Outdoor Unit Yellow Light Indicator - 17 flashes and 1 sec Off
NOTE: All of the Gree Air Conditioner Model Numbers below are applicable for the error codes on this page...
Gree AC Vireo Models: VIR09HP115V1A, VIR12HP115V1A, VIR09HP230V1A, VIR12HP230V1A, VIR18HP230V1A, VIR24HP230V1A, VIR30HP230V1A, and VIR36HP230V1A.
Gree Mini Split Air Conditioner Error Code Charts
Gree Mini Split AC Remote Control Button Names
Gree Mini Split AC Remote Control Icons Display Screen
Gree Mini Split Air Conditioner Air Filter Cleaning Procedure
Need help with error codes on your Gree AC? Please leave a question below and we will be happy to help.
How i can fix U8 error in my gree AC
in main board of gree dc inverter where ac 220v in ,, A bridge rectifire is use for dc voltages ..between the bridge and main capacitor a diode is used ,, if the diode is short the gree ac shows U8 ,,,0303331633
My gree ac remote locked .not working
I bought Gree split ac from China & Bring to Bangladesh.
I fixed it but cannot run as the ac is not responding with the remote, only showing white light blinking on the ac display
Gree splet ac i want salution
A Teco unit is almost identical to a Gree. The E5 error on those , it usually means that the outdoor pipe sensor has failed.
My gree air conditioner will not start. Shows U8
In main board of gree dc inverter where ac 220v in ,, A bridge rectifire is use for dc voltages ..between the bridge and main capacitor a diode is used ,, if the diode is short the gree ac shows U8 ,,,0303331633
2answers
Top Heating & Cooling Experts
Paul Carew
john h
