Garden Logo
Posted on Dec 05, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Homelite Blower HB180V carb adjustments.
Can you tell me the initial carb mixture screw adjustments and which screw is the Hi or Lo, left or right? Have been looking for an online operators manual with no success yet. Thanks.
Anonymous
Level 2:
  • Expert 211 Answers
  • Posted on Dec 05, 2008
Anonymous
Expert
Level 2:
Answers
211
Questions
0
Helped
173787
Points
374
Hi
high speed H=2 turns ,lowspeed L=2 1/2 turns
they are inscripted near the adjusting screws.
regards savumihai71
1helpful
What is the adjustment or how to adj, a single screw carb?
That is the mixture screw. Turn clockwise to get a leaner mixture, counter-clockwise for richer. For initial setting, try with the mixture screw open 1/4 turn. Start the engine and adjust the mixture screw for good running. After it is warmed up, lean the mixture until the engine starts to miss and then turn the screw about 1/8 turn CCW
1helpful
Model 3200. How should 3 adjustment screws be set(T,low and high for carb)?
Depressing the throttle slightly we listen to the engine. If the engine hesitates to accelerate, the LO screw should be opened 1/8 of a turn. If we open the screw too much, the engine will not accelerate smoothly and start shaking (too rich of a mixture). In this case we should close the LO screw slightly. We repeat this procedure until the engine reacts smoothly when adding power. Meanwhile, a readjustment of the idle speed may be needed.
After the LO mixture has been adjusted, we proceed with the HI screw adjustment. After securing the paramotor, we open the throttle to full power. We turn the HI screw to the left or right until the maximum RPM is reached. From this position just a slight turn to the right should cause a significant RPM drop. This means the lean side of the mixture has been achieved. Immediately we OPEN the screw to the left to prevent the engine from overheating!
Let us repeat once again this critical step:
At full power we tune for maximum RPM, then we close the HI screw more, until a drop in RPMs is noticed. When the drop in RPMs occurs we open the HI screw again until we reach maximum RPMs once again, and then we open the screw more until we have a drop of 20 to 60 RPMs. In this position the carburetor will be perfectly tuned slightly on the rich (safe) side.
Next, we should close the throttle and recheck the idle and the LO screw adjustment. If the carburetor was tuned properly, the idle will return to the normal setting described above.
To put it in a nutshell, if the engine idles and accelerates smoothly, does not smoke heavily and achieves 20- 60 RPM below maximum RPM, the carburetor is tuned correctly.
2answers
Need to know best way to adjust carb to get maximum performance on my homelite XL12
Regarding the adjustment procedure you generally start your low and high mixture screws at one turn from seat, or slowly turn them in all the way until they bottom out and then back them out one full turn. You will adjust the high speed mixture screw at full throttle and get the median point between too rich (loads up) and too lean (dies out). You will want to do the same thing with the idle mixture screw, just adjust at idle rpm. You will also adjust the low idle mixture screw to give you a smooth transition from idle to throttle up. Once this is obtained, you adjust the third or idle speed screw low enough so the chain does not turn at idle rpm but high enough so the saw doesn't cut off. Hope this gets you going.
5helpful
What is the fuel mixture for the Homelite vac attack II
The mixture is 50 to 1.
Hope this helps
If you need further help, I’m available over the phone at https://www.6ya.com/expert/matt_8dbc24bf722649ac
2answers
I have a hb180 homelite leaf blower and want to know how to adjust the 'two' little screws on the side and what they do
if its the carb screws your talking about
one it for fule mixture the other is for air,,,
air for tickover fule mixture for rev's
if its running well leave them be?
Oct 30, 2009 • Garden
9helpful
4answers
BLOWER only operates at half choke....then shuts off and can;t start again
your mixture screws probibly have to be adjusted.i have a homelite weed whacker and homelite leaf blower.
both had to be adjusted after i used them 6 or 7 times.theres a tool you can buy to move the screws.or you can be cheap like me and use a dremal tool with a cutting wheel on it and cut slots in to be able to adjust with a flat head.
turn the screws clockwise til there just seated,not too tight.then turn each one out counter clockwise to 2.5 turns and start adjusting from there.the first screw is the low setting and the second is the highs. i usally start with the highs.but u can do what you want. u can also youtube on how to adjust.
2helpful
Rebuilt carb need air and idel mixture screw settings. Blower runs but only a few seconds and then will not restart.
air fuel mixture screw shoould have initial setting of two turns out from lightly seated,check unit make sure cylinder is tight to base they only have two screws holding them down,if 2 cycle motor has a vaccum leak they will not run properly,also check compression if you have gauge should have a least 100 psi to run properly.
5helpful
What is my lo hi carb adjustment for a Homelite Super XL ? with Homelite/Textron Div. Carb.
Start with 1 turn out from bottom on both and adjust from there as needed. The screw closest the engine is low speed mixture adjustment and the outer is high speed mix. adj. Hope that helps. Dwain
Top Homelite Garden Experts
Jay Finke
Jay Finke
Thomas Perkins
Thomas Perkins
Sean Wright
Sean Wright
Are you a Homelite Garden Expert? Answer questions, earn points and help others
