My presario sr1810nx will on start fan when booting up. Nothing else happens. monitor is blank. I also have problems turning off computer when button is pushed. a new motherboard maybe?
a tech worked on it and installed a video card, there after the problem started.- Flemgail
Why do this expensive first.?
Its just a desktop, (and industry standard and easy to fix)
why not a PSU first. vastly more cheap.
i cant see that video card, it has name and model number
and that matters big time if the card uses more that 75watts.
(wrong PSU for the newer faster video card is doomed)
you failed to say what the problem was before, the card.
same,or just wanted faster video for say gaming.
tell why the new card, history also matters and intents.
lets do this the easy way. a list.
the unstated monitor and number of it, never ever shows any text ever at any time.
Blank to me means that, other say blank means windows dead.
(totally opposite in facts)
1: so you push the PC cases power button,
a: the PC is silent. ? (power cord connected, and any switch hear that cord entrance(1/0) is in the 1 position = on.
b: the PC PSU fan runs now, it must or the PSU is dead.
(answers are 99% the other 1% i handle in all cases(complex)
we use a voltmeter to test power, in all cases.
c: the PSU fan blows, (looking behind it in the PSU grill.)
not packed in lint and stalled, or dead.
d: the CPU fan blows, (slide lid off eyeballs on it)
e: the CD tray ejects on command, if this all happens 12v and 5vdc are working, yes it takes more.
in each case of testing above what fails , causes me to work that angle, that path, of power and logic inside.
if the PSU fan never spins even for the magic 1 second rule.
then the PSU is bad.
the exception is if things inside the case are shorted.
shorts cause all ATX class PSU made to shut down
(stops a fire ) (some do this for any overload, overvoltage and any undervoltage condition, I call those PRIME PSU's (best)
This is normal for short.(inside)
to find shorts, we remove things from the inside if the case
called stripping PC. down.
first HDD (just power cable)
next CD (same just powercable
next the Video card, pulled, oops PSU now stay on, oops.
next all ram pulled. PC may beep due to missing ram. but power goes one. and may stop but you saw power happen.
last is the jumper test of a PSU.
we unplug the PSU. 24 pin connector.
then jumper as see here.
pin 16 to 17
pull the conn,. and psu end jump it.
turn on PSU and it must run its fan full time.
it will have all the voltages seen here.
http://www.pcdied.com/power.html#Jumper
SOURCE: my Presario SR1750NX won't boot up
hold the power button for 10 seconds it turn off ur cpu and then start the cpu and hold F5 key u get windows boot menu select safemode try to login after login check in the controlpannel poweroptions chek in advance option see the menu down wheather it is in standby then change it to shutdown and apply the setting. and check it out it may work r else please try to repair the os.
SOURCE: Monitor goes blank after seeing XP during boot up.
did u replace the video card with the same kind of model ? i guess yes ... when system starts hit the f8 key and than go in to safe mode ... mouse wont work so use arrow on the keyboard .. and in the safe mode just log in to admin account if available or login to ur account and see if that still happens .. and if it doesnt ... remove the drivers for the graphic card from add and remove programs and restart the system and go in the normal mode and than install the drivers again ... and if the display disappears in the safe mode or u have install a different graphic card than ... reseat the memory cards and that should resolve the issue .... if that doesnt work out when the system starts hit f1 and stay on the BIOS screen for 30 mins if the system doesnt loose display than u need to reinstall OS ... that will surely work out ... the resolutions given above if u follow them correctly u will have a working system in no time
SOURCE: my compaq sr181nx diplay monitor is now blurry
This could be a faulty monitor. Trying plugging in a different monitor to the computer.. If you continue to have the same problem with the second monitor, then it is your video card or on board video that is going out. If the video is fine after you tried the second monitor, then you need to get a different monitor for your system.
SOURCE: new processor for my compaq presario sr1810nx
Try to add an extra 512mb of ram and get a descent Processor, but make sure you have a good graphics card, as it is also important to gaming. Now your computer supports this:
So a AMD Athlon 64 X2 4800+ would be sufficient as long as you got a good graphics card.
Thanks,
Christian
