SOURCE: mixed colors and separation of colors
Common problem known as convergence. The most common reason is the failure of convergence ics. these ics fail all the time because there big and get fairly hot. there is a possiblity that it can be reconverged if the convergence cuircit is not damaged
SOURCE: Samsung 52" tantus pch521r convergence panel
I found a this SITE that carries that convergence assembly for your TV.
Good Luck.
SOURCE: rear projection tv screen warped
Hi, this TV is repairable and you will have to replace two devices. the first is the Convergence board. this device regulates the convergence of the RGB stream so it can be projected evenly. it works in conjunction with the CRT's and deflection assembly and the Focus pack(module). The second device that will need to be replaced is the Focus pack(module). This module is malfunctioning and is causing the smudges and warped look at this time.
Replace these two devices and it will fix this set. i will post the Part numbers below along with there respective prices as well.
Focus Pack(module).--- Part Number-- BP59-00005A---
$38.95
Convergence Board assembly--Part Number---BP94-00383A---- $165.95
Please rate and god bless:)
