Usually with a blown speaker you will get sound but it sounds like there is an abundance of paper very loose on the speaker, so if there is no sound at all try taking the box apart if you are familiar with stuff like this and check to see if there are any loose wires or blown capacitors
Josh,
Thanks for the input. I've blown speakers, before, and experienced the sound you described. I don't know that I can correct the problem myself, but you have given me the confidence to avoid replacing the sprakers without further evaluation.
Regards,
Matt
This amp comes factory with cheap 75 watt jensens. They are blown, no reason to waste time troubleshooting the amp for blown speakers.
Speakers can be blown in 2 ways, the voice can get hot and warp which, will still work but rattle because the coil rubs the magnet inside as the cones try to move back and forth, OR they get too hot and burn out completely, severing the winding of the voice coil, which will give no sound at all, dead silence.
I had the same amp and the speakers blew, didn't make a sound. Speakers can warp the voice coil and rattle AND they can blow out completely. Before you tear the thing apart use common sense and try the simplest option first. If it plays through the headphone jack, it probably has output so connect a normal speaker to it or a cabinet, it has output jacks for cabs R+L. BECAUSE, it is already in stereo, there is no mechanism inside the headphone plug to change it. I also have a manual if you need it. Its .pdf and would have to email it to you.
SOURCE: peavey minx 110 no sound from main speaker but
Inside the headphone jack is a built in switching mechanism. It is there to cut off the sound to the speaker when you are using headphones to practice quietly. For some reason or another it seems as if this is no longer working correctly. One of the causes of this can be bad solder joints on the circuit board where this jack is located. Another cause is a failure of the jack itself. If you are capable, Take the circuit board out and have a look. Hope this helps.
SOURCE: i have a line-6 spider 30 amp that started humming
output caps. dont beat up your amp. crazy
yostamplifier.com
SOURCE: Phonic S715 "15" 2way
This speaker is not an active one. This means that it hasn't integrated amplifier, so you need an external one. The cable from the amplifier goes to the speaker. Remove the woofer in order to get access at the inner parts and check these points:
Post me back if there is a crossover in use or it is direct connected and any other points of interest you came up, in order to guide you further.
In case of a problem or clarification or further details needed, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct fixya link: http://www.fixya.com/users/technical114
SOURCE: No sound will come out
It sounds like to me that you blew the speaker. We here at Pro Line Music are Peavey dealers. If you can not check for continuity of the speaker you can bring or send it in. 215-736-8055
SOURCE: Behringer No Input Signal
Mic level in the windows control might be muted or off. The sound functions are a control panel iterm Or in Macs it is a CDEV.
Also check to make sure the program has that input enabled as well.
and make sure you start out with fresh batteries, double check where you have things plugged in, so you are not plugged into the worng port plug on the computer
The speakers are blown if you have sound through the headphone jack. I've used that same crappy amp with the same jensen speakers. Speakers can be blown in 2 ways, the voice can get hot and warp which, will still work but rattle because the coil rubs the magnet inside as the cones try to move back and forth, OR they get too hot and burn out completely, severing the winding of the voice coil, which will give no sound at all, dead silence. It has sockets on the back for a left or right speaker cabinet to plug in, it would be that simple to plug another speaker in and see if it works.
