NEED TO REPLACE FILM ADVANCE LEVER / PHOTO PLUNGER
SOURCE: Film advance lever and shutter release button are "stuck"
No, it is not the battery. My guess is that the film leader did not stay in the take-up spool and is now bunched up around it. Try rewinding the film carefully as you normally would but remember that you are only rewinding a small portion of the length. You can even just open the film door and start over. You will only loose 3 or 4 frames on the roll.
SOURCE: film advance lever.
Do you press the shutter button to release the lever for the next photo? That's how you advance the film from the exposure to light, when first insterting the film.
SOURCE: Nikon EM film winding lever is stuck. Can I repair this myself?
Bad news. I have an EM on the junk pile for a similar reason. In my case, the lever stuck and when I tried to advance the film, the plastic on the top of the camera body fractured and the whole mechanism separated. The current E-bay price on an EM body is under $30. Since the EM was made out of plastic, it is not repairable. If you have several lenses, it will be worth the low cost.
I have had Nikons of various models for over 50 years and in my opinion, until they fail such as your has, the EM is probably the most comfortable non-professional 35mm camera to hold and use that Nikon ever made.
SOURCE: my nikon fm10 film advance lever is stuck, i can't
You may end up sacrificing the used film or you can rewind it early.
I have had it happen that the film sprocket holes had striped out causing the advance sprocket to get out of sync with the film making it ride up onto the area between sprockets and creating a jam.
If you can, rewind the film onto the feed roll to preserve the exposed portion and then remove it from the camera.
Try the film advance then with an empty camera, releasing the shutter and repeating the cycle to determine if the advance mechanism will now act as it should; if it does, then the film was probably at fault and it may never happen again.
If you cannot respool the film, I would take it to a professional photo lab and have them unload the camera in a dark room if you want to try to save the pictures already on it.
SOURCE: My Nikon FE film advance lever is stuck. It does
Have you tried fresh batteries and setting the shutter speed dial to M90 or m250 whichever you have? If this does'nt work you can remove the camera bottom plate and gently pull a lever away from the advance cog. Some times things get out of sync in there. Sorry I can't be more specific but I did this many years ago. Good Luck.
