The minute circle is stuck at 2 minutes, while the second is centered at 12 and hour is centered at 12 also. How do I reset the minute hand to centered at 30 also. Both the hour circle and the minute circle should be at parallel to the second hand. Please advise.
same problem here except minute hand only resets to about 6 minutes (6 notches to the right of the center 30)same problem here except minute hand only resets to about 6 minutes (6 notches to the right of the center 30)
You can't post conmments that contain an email address.
To use 12- or 24-hour time for your watch, please follow the instructions below.
1. Press and hold the "Set" button for 2 seconds. The "Set" button is on the lower right side.
2. Press the "Date Advance" button on the upper right side. This will reset the seconds.
3. Press the "Change Mode" button on the lower left to set the hour. The hour will flash. Press the "Date Advance" button until the correct hour is displayed.
4. Press the "Change Mode" button again to set the correct 10s unit (first digit 1 or 0) for the minutes. Press the "Date Advance" button until the correct first digit of the minutes is displayed. Repeat this step to set the second digit of the minutes.
5. Repeat Steps 1 through 4 of this section to set the year, month, date and day and whether to use 12- or 24-hour time for your watch.
6. When finished, press the "Set" button (on the lower right) to return to the current time view and lock in your settings.
The three small dials on this watch are all part of a "stopwatch" system. The small dial at the 12 o'clock is for tenths of a second( each half circle completed is one second or 1 whole rotation equals 2 seconds.) the small dial at the 6 o'clock counts a full 60 seconds for each revolution, and the dial at the 9 o'clock counts minutes(one full circle equaling an hour.) when the stop watch is started the 12 o'clock and 6 o'clock dials will start at the same time. you will notice that every half turn on the top dial equals one "tick" on the bottom dial. After the first minute of timing the top dial will stop ticking as it is for more precise timing of things that take less than 1 minute. each full rotation of the bottom dial will then equate to one "tick" of the 9 o'clock dial. hence the three dials counting tenths of a second, seconds and minutes. the setting of these dials is fairly easy once you understand the purpose. on the side of the watch there are two buttons(one top and one bottom) with a setting wheel in the center. When in use the top button starts and stops the stopwatch and the bottom button resets the counters. To set the watch simply pull the center wheel away from the watch all the way(2 clicks) set your minute hand and hour hand and then tap the bottom button repeatedly until the small dials all line up straight up. once that is done push the center wheel button halfway into the watch or one click to set the date. then simply push the wheel the rest of the way in and voila!!! hope this answers some questions
3.
is displayed.
5.
Normal screwed down. First pull out position. Second pull out position.
Setting the Time: Pull out the crown to position 3. Rotate the crown to set the exact time. Ensure that you are in the daytime12 hour segment by allowing the hands to pass 12 o'clock and notice if the date moved on or not. If the date changed, then you will need to advance at least 2 hours before moving on to set the date. If you do not need to change the date, return the crown to position 1.
Setting the Date: DO NOT DO THIS IF THE WATCH IS BETWEEN 8pm & 2am Pull crown to position 2. Rotate the crown clockwise to set to the correct date. Return the crown to position 1.
Setting the Alarm [12 hour] Pull the crown to position 2. Rotate the crown anti clockwise to move the alarm hand to the desired time. Return the crown to position 1. To activate the alarm, press the 8 o'clock button. You will hear 2 beeps. To deactivate the alarm, press the 8 o'clock button. You will hear 1 beep. NB If the alarm is not cancelled while it sounds the first time, it will repeat again in 2 minutes time. The alarm sound last for 15 seconds. If the alarm time coincides with 1 beep of the countdown, the alarm function will be cancelled.
Battery EOL [End Of Life] The Swiss ISA 8270 movement uses a 395 cell and will signify a low power state by advancing the small seconds hand 4 steps every 4 seconds.
Setting the Countdown You can specify a countdown of between 1 and 10 minutes. Press the 4 o'clock button to enter setting mode. You will hear 1 beep. Press the 4 o'clock button to move the central timing hand successively to the desired countdown time. Wait 3 seconds for the watch to automatically exit the setting mode. You can change the duration of the countdown [except in the last minute] at any time. e.g. If the countdown is set to 10minutes, and you now want to change the countdown to 9 minutes, press the 4 o'clock button. The hours/seconds counter sub-dial will perform one complete turn and then stop at 60, before continuing.
Activating the Countdown: Press the 2 o'clock button to start the countdown. You will hear 2 beeps. The hours/seconds counter sub-dial will perform one complete turn and then stop at 60, before continuing. When the countdown begins, the hour/seconds counter sub-dial indicates the seconds with 1 step every 2 seconds, and the central timing hand indicates the minutes with 1 step being 2.4 seconds.
Countdown tone: There are 2 beeps every minute. in the last minute: 50 seconds=1 beep. 40 seconds=1 beep. 30 seconds=2 beeps. 20 seconds=2 beeps. 10 seconds and less=1 beep every second with zero being 1 second long beep. Timer function automatically starts.
Timer: After countdown has finished the timer starts automatically. The central timing hand indicates the minutes with 1 step every 12 seconds. The hour/minutes counter sub-dial indicates the hours up to a maximum of 96. Press the 4 o'clock button to see the timer seconds [display lasts up to a minute]. Press the 4 o'clock button to see the timer hours. The timer has a maximum time of 96 hours [4 days] after which the hour/seconds sub-dial counter will stay at 0 and the central timing hand will stay at 12.
Start/Stop Timer: Press the 2 o'clock button to stop the timer. You will hear 1 beep. Press the 2 o'clock button to resume the timer. You will hear 2 beeps.
Setting the Countdown & Timer: Countdown reset: Press the 2 o'clock button to stop the countdown. You will hear 1 beep. Press the 4 o'clock button to reset.
Setting the Timer: Press the 2 o'clock button to stop the timer. The hour/seconds counter sub-dial will show the elapsed hours and the central timing hand the elapsed minutes. Press the 4 o'clock button to view the seconds elapsed on the hour/seconds counter sub-dial. Press the 4 o'clock button to reset.
Resetting the Hands: If the hands do not zero correctly, which might occur after a battery change or a violent shock, you can make adjustments by doing the following settings as long as the countdown is not in operation. To correct the hour/seconds counter sub-dial, pull the crown out to position 2 and wait 1 second. Press either the 2 or 4 o'clock button; the central timing hand will turn and stop [not necessarily at 12]. Press the 2 o'clock button to increment the hours/seconds counter sub-dial hand to position it at 60. To correct the central timing hand, press the 4 o'clock button to increment the hand to the 12 position. Return the crown to position 1.
If the battery had been replaced, the central timing hand defaults to the 10 minute position. If the battery had not been replaced, the central timing hand will return to the previously set position.
go to Buliva web site and look for the chorograph 561/598
FEATURES
1. Hours, minutes, seconds and date display.
2. 60 minute Chronograph (CHRONO) with minutes and
seconds display.
3. 24 hour hand, permanently synchronized with the normal
12 hour hand.
A. SETTING THE TIME
1. Pull the crown out to position “3” (See diagram). If the crown has
a “screw-down” lock, then unscrew the crown lock first by turning
the crown toward you, then pull it to position “3”. Do not forget to
screw the crown back “IN” after all setting is completed.
2. Turn the crown towards you (hands moves clockwise) until the
date changes at approximately midnight.
3. Continue turning the hour and minute hands to the correct time.
If it is afternoon you must go past 12 o’clock again (noon) to set
the correct time.
4. When the correct time is set,push crown back to position “1”.
B. SETTING THE DATE
1. Pull crown to position “2”(See proceeding diagram).The watch
will continue to run.
2. Turn the crown away from you until the correct date appears.
3. Once the date is set, push the crown back to position “1”.
Note: Do NOT set the date between the hours of 8:00 PM and
3:00 AM.This would not damage the watch,but the date may need
to be reset later.
C. CHRONOGRAPH (CHRONO) ADJUSTMENT
If the chrongraph second hand is not positioned at the proper
starting position (12 o’clock or “zero” position), use the below
procedure.It does not need to be repeated unless the watch
receives an impact sufficient to move the hand out of position, or
the Battery has been changed.
1. Pull crown out to position “3”.
2. Push button “A” to move the Chrono Second hand (long hand) to
the “0” or 12 o’clock position. Each button push will move the
hand one step – BUT holding the button down will advance the
hand rapidly.
3. Push crown back to position “1”.
D. USING THE CHRONOGRAPH (CHRONO)
Note: The maximum chrono reading is 60 minutes, However the
chrono will continue running once 60 minutes has passed. The
resulting one hour periods may be added together mentally to keep
track of longer periods.
For example – If you know that approximately one hour has
passed since you started the chronograph, and the chrono reads
25 minutes, then you know that the chrono has been running 60
minutes plus 25 minutes, which is one hour and 25 minutes.
1. Push Button “A” to start the chronograph. Push button “A” again
to stop the chronograph.
2. Push button “B” to return the two chronograph hands to the
“Zero” or starting point.
3. The Chronograph can be stopped and started again
(Button “A”), repeatedly, to “ADD” times together.
BOOK NO. 561/598 Chrono FS00/01/10 BOOK NO. 561/598 Chrono FS00/01/10
Watch Setting Guide
4/2007
To set the Time: 1. PRESS the [Select] button and hold in for 2 seconds. Located in Field 3, the seconds will begin to flash (Fig. 11). 2. PRESS the [+] button to scroll the seconds upward or PRESS the [-] button to reset the seconds to zero. 3. At the seconds desired, PRESS the [Select] button to move to the next setting. Located on right of Field 2, the minutes will begin to flash. 4. PRESS the [+] button to scroll the minutes upward or PRESS the [-] button to scroll the minutes downward. 14 5. At the minutes desired, PRESS the [Select] button to move to the next setting. Located in the center of Field 2, the hour will begin to flash. 6. PRESS the [+] button to scroll the hour upward or PRESS the [-] button to scroll the hour downward. 7. At the hour desired, PRESS the [Select] button to move to the next setting. Located in Field 1, the 24 or 12 hour clock setting will begin to flash. 8. PRESS either the [+] or the [-] button to toggle between the 24hr and 12hr. Note: If the 12 hour clock is chosen either AM/PM will appear below the hour in Field 2. 9. At the clock setting desired, PRESS the [Select] button to move to the next setting. Located in the center of Field 2, the year will begin to flash (Fig. 12). 10. PRESS the [+] button to scroll the year upward or PRESS the [-] button to scroll the year downward. 11. At the year desired, PRESS the [Select] button to move to the next setting. Located in the center of Field 3, the month represented by a number will begin to flash. 12. PRESS the [+] button to scroll the month upward or PRESS the [-] button to scroll the month downward. 13. At the month desired, PRESS the [Select] button to move to the next setting. Located to the right of Field 3, the date will begin to flash. 14. PRESS the [+] button to scroll the date upward or PRESS the [-] button to scroll the date downward. Note: Once the user has determined the year, month and day, the Wristop Computer will supply the day of the week in Field 1. The American month/day -view can not be changed to a day/month -view. 15. At the desired date, PRESS the [Mode] button to accept the changes and return to the main mode. Note: If the user does not press any button for 1 minute in the setup mode, the display will automatically exit setup.
