Just built out a new computer with a Giggabyte GA-Z77-D3h mothorboard with 8 gigs of corsair vengance ram, an OCZ SSD, a Corsair TX650 psu. I have a few fans, and an old video card. I plugged everything in, got everything nice and situated, and the computer is stuck in a power loop. I have done everything i could think of to remedy the situation. I have: tested each stick of ram 1 at a time,. no change used just the cpu and board, no dice checked and rechecked every connection and re-seated the CPU, no change Plugged PSU into my old old old mobo and chip, Ran perfectly. Is this just a dead motherboard, or is there something else i can try? I haven't installed an operating system or messed with anything yet, because it wont even load the bios or CMOS.
SOURCE: p5k motherboard
remove the ram, do you hear beeps?
you might want to get your hands on one of these
http://cgi.ebay.com/New-8digit-PC-Motherboard-CPU-Ram-Analyzer-Test-Card_W0QQitemZ190231285206QQcmdZViewItem?IMSfp=TL0806211611r25031
if link broken click here
Reseing the bios shouldn't be a problem go ahead, or is there something I don't know? does it void the warranty? I don't think so.
SOURCE: Asus P5Q-VM CANT BOOT
CPU Should work with board.Try removing cpu and replace in socket check for bent pins if all is well..reinstall.make sure to use pad or silver paste and reinstall fan.rebootRichardm69
SOURCE: Hi, I have just purchased a new system and after
You could try another power supply. Otherwise, I'd say it's DOA
Testimonial: "I have tried 2 power supplies with it (one brand new) guess I should send it back. Thanks"
SOURCE: Hi, I am having an
Sounds like a procie problem.
Check your processor's heatsink, if it really sits flat on your processsor.
Try to replace with another processor, take note of your socket if that is for the board's requirement.
Put a new heatpste too.
Then tell us the effect.
Thanks for using Fixya!
SOURCE: I just bought my new
Hi, The recommended PSU for your card is 550W.
After you connect it to your motherboard you have to connect a (6pin) PCIE power connector
to the card. Without it the video card will not display anything.
