The power light under the screen blinks about every 5 seconds and keeps showing a white screen when it blinks.
SOURCE: Mag Innovision LT576s won't power up
Clearly your monitors are evil. Try turning them on at home and see how you fair out. :)
Cheers,
Mike
SOURCE: Mag Innovision 765S power supply light blinks and monitor power led blinks and no picture
I'd suggest looking at the mainboard. I assume the blink is rapid? A slow on, followed by a short off and back on again is normal. The fast blink thing is a mainboard issue, and the absence of blink (or light) is power "supply dead."
There is a problem transistor on the mainboard that seems to be the problem most of the time. Replacing it takes about 5 minutes if you have the tools and the talent, and the parts cost under 3 bucks at Radio Shack. Just pick up a pack of NPN switching transistors and de-solder / solder your way to a working monitor. There's usually only one on the board, so it's easy to spot.
SOURCE: Mag Innovision LT776s Model 780
Sounds like an inverter problem. If the power supply is internal replace the capacitors coming out of the voltage regulators. These are usually 1000mf and/or 470mf. If that doesn't do the trick look up the numbers on the 8-pin chips that drive the secondary transformers on the inverter to see if they are getting the right voltages.
Good Luck!
SOURCE: Black screen
It is most likely that the filter capacitors on the power inverter board have failed. I took mine apart and found seven swollen capacitors on the this board, they fail prematurely and seem to be the only thing wrong with the unit. I replaced them and now it is working just fine.
six 470uf 25v electrolytic capacitors and one 220uf 25v Capacitor.
you should not attempt to repair this yourself unless you have some electronics training since there is a shock hazzard involved and also these capacitors will blow apart if they are installed incorrectly (very messy experience).
SOURCE: MAG Innovision LT916S monitor problem
Should have clarified I have a Mag lcd LT916s and need a backlight bulb.
Thanks,
Cindy
