The opeen button willl sslide but the door will not open.
SOURCE: Stuck battery/ScanDisk card
Unfortunately, you have to force the battery door (very carefully) to open it, and find what is wrong with it.
It is more likely that when closed the battery door, it was forced and it slided out of one guide channels.
You need to practice a little bit before to try it with force (genlty but with firm force), but the only way to do it is slide the button to open it, and at the same time slide to the side and pull the battery door, everything at the same time. Try it until you are able to open it.
Using any kind of tool (such a plastic pry tool, a small screwdriver, etc) to force will leave marks in the housing, and it's very possible that the plastic locking tabs will break, causing that you will open it, but unable to close properly again.
Best regards,
SOURCE: My Canon PowerShot A570 IS wont turn on and it was
Your problem is likely due to weak/worn out batteries or corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera and give them a full charge (assuming that you're using rechargeable batteries). This cleaning clears the problem about 90% of the time. If it doesn't work for you, your batteries may be due for replacement, or the camera may have a problem that requires professional repair.
SOURCE: How do I use the self timer on my PowerShot A570 IS camera? Please help...
Press the Center Button
By pressing the center button on the four-way controller, you'll open up the Function menu. This menu has the following options:
The Third Option is Having Self Timer ..... Check
SOURCE: The memory card on my
SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
SOURCE: hi- my husband was playing with
There is a switch on the side of the memory card and is very tiny to find. Set it in the opposite direction - unlock.
