SOURCE: EMERSON DVD PLAYER CLICKING NOISE..DISC ERROR MESSAGE..HELP!!!
Had a similar problem. Called for support, but was told needed new reader. I took off the cover and manually slid the reader mechanism back and forth a few times. After doing this, tried another dvd and it worked. Apparently it was stuck and not able to move to read the dvd. Give this a try.
SOURCE: DVD not working!
sound like the lazer drive unit is faulty.
Expensive to fix.
My suggestin is by a new one.
I had same problem, took the back cover off. two scews that are right were the ribbon connects to the read head I believe are potentiometers adjusted with eyeglass screw driver a couple attempts it worked. I also disconnected the plug for external battery and left unpluged since I don't use battery
SOURCE: dvd player doesn't recognize dvd's of any kind
jusguessin should call Toshiba quickly. The units have a 1 year
warranty. Do not open the unit or it will void your warranty (I know, I
do Toshiba warranty repairs on their recorders. If anything will make
be void a warranty, it's a consumer who opens the unit and pokes around
inside).
mooch, clean the laser head. I wish I could refer you to a FAQ because this is about the 10th time today I have written this.
Open the unit. Remove the DVD drive. Take the top off of the DVD drive.
Clean the lense with a q-tip with a little windex on it. Work the head
up and down gently. Reassemble and test. If problem presists, go buy a
new one.
SOURCE: Can this be fixed?
i have an audiovox dvd player model D1718 . i put the disc in and it says it is loading but then comes up no disc . how can i fix this problem?
