Flashes the blue polaroid screen then goes black ,I hear a buzz coming from the inverter board. I have replaced both inverter boards and the same problems exists .I have alway replaced 4 caps 35v 1000uf which all looked ok.. I need help with this set ..PLEASE!
SOURCE: I Think NO expert can help this problem because it free answer
I think I may finally have the answer for the "black screen of death" for the 42" Polaroid LCD televisions. I was having the same issue with the screen going black after a couple minutes of being on. I would shut it down then turn it back on and it would work again for 5-10 minutes. On the "power board" which is the board on top, there is a little red light that turns on when the screen would go black. above that there are 4 little switches, the lower on says BURN. I simply switched that over and the television has been working for 2 days for 8 hours + each day. Hope this help. Let me know
SOURCE: Polaroid TLX-04244B Remote wont work
5 Digit code is 15231
3 Digit code is 494
Hope that helps, took me about 4 hours to get that figured out!
SOURCE: screw size needed
I strongly advise and recommend you get the details and if possible the screws from the shop you got it from.
This advise is enssential so as to get the best from the certified sales representative
SOURCE: Screen goes black after couple seconds on my Polaroid 42" LCD
I had a TLX-4240B 42" Polaroid LCD TV and the screen would go black after about 10 minutes. There was still sound. I removed the two covers exposing the circuit boards behind the TV. I powered up the TV and waited for the screen to go black (I was going to start trying to pinpoint where the issue was with my trusting meter) then noticed a red light would come on when the screen would go black. there were 4 mini switches right above the red light. I switched the one that said burn and the TV has been working great since. good luck and let me know!
SOURCE: If anyone is in need of Polaroid lcd tv parts contact me
usually capacitors are the problem on the TDA03211c power supply. 450v (volts) @ 10uf. change both. beside inverter filters.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
