I just bought a W1954TQ and have hooked it up to my Mac Book from 2009. The monitor has a picture of the galaxy but refuses to do anything else. The CD that came with the monitor doesn't work - the files are locked and and I can't open them. I have looked at the LG website and there does not appear to be any driver for Mac. How could this be?
SOURCE: LG dvd model no: HT
there are switches needs to be in contact when the loading tray is closed and open. it is placed under the tray mechanism. investigate ribbon cuts and bends. replace it
SOURCE: My MacBook doesn't recognize
if your computer came with a motherboard disc the drivers could be on it
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again, sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems
hope this helps
SOURCE: My LG 1715S monitor that
Normally the option to reset the monitors default settings is available on the On Screen Display.
Try to Go to Menu look for Advanced Menu or any of that sort and the choice to reset it to factory default should be there.
Otherwise a hardware problem with the color mixer is the cause and that would have to be sent to the service center for repairs.
Other things you can try is to swap cables and try it on a different computer or a TV box.
If the same result happens then definitely it's the color mixer that has gone bad. Maybe it tripped or the part already given up.
You can try contacting LG through 1 (800) 243-0000
Hope this helps!
SOURCE: Remote won't work. Tried new
To confirmed if the remote control is working fine, aim the remote control sensor(IR emitter) directly to your cellphone camera. While pressing any button key on the remote control, you can see the flash of an infrared emitted by the remote control if it is working fine.
If you've confirmed that the remote control emitted an infrared but still the tv won't communicate with it, this is an indication of faulty IR sensor board of the TV. Check if there's an obstruction from the IR receiver in front. Keep away all of it, clean the plastic window of the IR receiver with soft clean cloth.
If the symptoms still persist, you have to replace the IR sensor board. Check the actual part no. of the board before ordering.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
SOURCE: lg dvd recorder/vhs combo doesn't read dvds
Buy a DVD cleaning kit follow the instructions, sometimes brings it back to life. If no change! the assembly will need to be replaced,"not cost effective" cheaper to replace.
