Try reset utility
for the 2nd gen.iPod Reset Utility 1.0.4 for Windows
iPod Reset Utility 1.0.3 for Mac
for the 1st. gen.
iPod shuffle Reset Utility 1.0.1 for Mac
Connect the included USB cable to your iPod Shuffle.
Plug the opposite end of the iPod Shuffle cable into an open USB port on your computer, which must be turned on.
Check the light on the iPod Shuffle. If the light has turned on, the iPod Shuffle is properly charging.
Using iPod charger
Plug the iPod charger into a working electrical outlet.
Plug the opposite end of the iPod Shuffle cable into the USB port on the iPod charger.
The iPod Shuffle should begin charging immediately.
hope this helps
I had the same problem...now no lights no nothing. Its in essence...dead.
I HAVE THE SAME PROBLEM NEED SOLUTION PLEASE
i have the same problem
It also happened to me on the first day on used it. I can't use the iPod reset tool because the tool does not recoginize that the Shuffle is even connected to my computer.
iPod shuffle 2nd Gen - Blue
i have the same problem. i have TWO ipod shuffles 2nd generation, and for the past week suddenly my pc doesn't want to recognize when EITHER are connected. the light will flash sporadically like it's trying to get a charge for maybe 15 seconds, then nothing. Itunes doesn't know it's there. HELP!
it cant be done.. I can't use the iPod reset tool because the tool does not recoginize that the Shuffle is connected...
