Oil and water mixing in pump and overflowing at dip stick breather i have changed the oil mixes pretty fast what can i do?
What you have is a bad seal or a crack within the pump crack more common if any water was left in it during the cold winter
that makes sense can i change the seals myself? if possible any suggestions on were to purchase them?
i have had luck by just putting the model number of the pump on google seach to find parts as for can you do it your self you need to take your time and remember where the parts go back i lay them out in rows
If unloawer valve unloads when trigger released replace u or v packings in pump head.
SOURCE: Oil for Comet pump
aftermarket oil will be fine just use same grade of oil,all manufacturers want that extra kick,
