Motorola Mobility RAZR V3 Logo
SHUYU JIN Posted on Jun 22, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Black screen 'the phone is black screen when it's on. It shows nothing on the screen, I can't see any incoming calls and tests!
bernard
Level 2:
New Friend:
  • Expert 71 Answers
  • Posted on Aug 08, 2012
bernard
Expert
Level 2:
New Friend:
Answers
71
Questions
0
Helped
98147
Points
101
HI
make hard reset to the phone 9you will loose all your data)
if it does not help probably the screen is dead -or you will have to replace the screen or to buy a new phone
bernard
http://www.rylwy.com/
4 Related Answers
Anonymous
  • 91 Answers
  • Posted on Apr 23, 2007
SOURCE: Screen and Faceplate non-responsive
OK again BATTERY!! replace that then see. If that isn't the problem that should be a connection problem (if you haven't severed the electrical ribbon in any way)
A
Anonymous
  • Posted on Sep 22, 2007
SOURCE: blank black screen
That happened to my phone and when I took it to the shop, they said that the phone got wet.
Anonymous
  • 84 Answers
  • Posted on Feb 03, 2008
SOURCE: incoming calls
check to see if your calls are being forwarded. try *72 to deactivate if they are.
wg
Anonymous
  • 567 Answers
  • Posted on Jul 12, 2010
SOURCE: My cell phone has locked itself. Likely from me hitting a key.
Hi you should buy a New Universal Cell Phone Turbo Sim Card Unlock GSM Card from ebay, it only cost $1.00 and can be use to unlock any cell phone its interesting i think you should try it.
Touch Screen Stuck On Incoming Call Screen?
Just Unplug the Power Supply and replug it in after 5 minutes, That should be able to fix the issue.
1helpful
My Motorola Photon Q will not receive or send texts or calls, what can I do?
I would check with sprint to see if your account is up to date. Otherwise, I would suggest going to your settings and see if you can update your phones's prl and profile. go to settings, tap "About phone", Tap "System updates", then tap each option. Good Luck!
2answers
My HTC legend will not vibrate or play ringtone on incoming calls. The screen lights up as it should when the phone is being called, but no sound or vibrations are being produced. I've played around...
First back up you phone on to your computer or one of the cloud services. Go to the Google Play store and search for backup and find a backup service that you would like and perform a factory reset on your phone if this doesn't work then your speaker is not working and then you might as well replace it.
Sep 03, 2012 • Cell Phones
The phone gets cut off before I can anwer the incoming call
If you do not pay your bill, you will not get incoming calls or messages and you cannot call or send messages. Your phone will not work if you do ot pay for it.
According to the article, and other information I've been reading, there is more than one possible mode a GPRS/EDGE phone network can be configured to operate in, 001 and 002 being the most common. In mode 001 if an incoming call occurs during data use the data session will be terminated and the call will come through. In mode 002, the call will go straight to voicemail. Apparently the majority of 2G networks in the world use mode 002! confused.gif mad.gif
It's possible to use the iPhone's field test mode to see what Network Operating Mode is for the network - to do this, first disable 3G, then go into field test mode by dialing *3001#12345#* from the phone app keypad then pressing call, then go to GSM Cell Environment -> GPRS Information, and scroll down to "Network Operating Mode".
I've checked this for all 5 networks and in all cases (at least where I live) it was mode 002 - the mode which doesn't allow for incoming calls when 2G data is in use. rolleyes.gif
The ramifications of all this are that any time you use data on GPRS/EDGE you will miss incoming calls and unless you have a missed call service with your provider, you won't even know you missed them, as they will not show up on the phone. (And the missed call texts themselves will be delayed as well)
Not only can this be caused by actively using an app such as safari, (or leaving a data using app active with the screen locked) but background mail checks and push notifications will cause it as well. frown.gif So if your phone is lying there unattended and it happens to do it's 30 minute (or whatever) mail check just before someone tries to call you - missed call.
Having push notifications enabled is even worse, because it tries to keep an active data session as much as possible, and re-establishes this connection every time the data connection is interrupted.
One good example of this is if you have push notifications active, try making or receiving a call, hang up, and call the phone back in less than 30 seconds or so of the previous call - missed call.
The reason is that the GPRS/EDGE connection was interrupted by the first call, so when the call ended the phone immediately tries to re-establish the push data connection, and on a slow connection this takes up to a minute to do and then go idle before the phone can receive another incoming call.
I'm stunned that a problem of this magnitude (which is not really the phones fault at all, but is made far worse by turning on push notifications and background email checking) has been seemingly covered up and glossed over for so long - the O2 UK forum has a message thread with over 500 people complaining of frequent missed calls, with no official acknowledgement from O2 on what the cause is, with the only suggestion being to turn off push notifications. (Which will ease the problem but won't cure it)
What baffles me is why the networks don't just run in mode 001, which allows incoming calls to interrupt the data session - surely an incoming call is more important than finishing downloading an email ? Surely with more and more phones relying on data and trying to hold persistent push connections open, this is only going to become more and more of an issue ?
Perhaps someone like Planner could comment on why networks might not be using mode 001, I'm assuming it either has some drawbacks or compatibility problems with some phones, or is an added cost to support. Is there any likelyhood of this ever changing ?
Now it makes sense why if you're using a network where you tend to get 3G most of the time (such as I do with Orange or 3) then the problem is minor because you're not on 2G very often, but if you're on a network where you will be using GPRS/EDGE a lot (cough, O2) then you really can't afford to leave push notifications enabled, unless you like missed calls...
1helpful
Phone screen went black, only AA&T 3Q, time and battery indicator are showing but can not move screen/change screen, screen shows incoming calls but, I can not move to answer
Force restart it by pressing and holding both the POWER and the HOME buttons for around 5 to 10 seconds until you see the apple logo.
For more iPhone / iPod touch tips like jailbreaking and unlocking, click here.
2answers
My screen will not display anyting. it is black
if incoming & outgoing is ok then change the disply.
if no incoming or outgoing then go for flashing
Screen Blacks out on receiving calls
You need to update the software/firmware of your phone. Doing this usually solves the problem. if it doesn't then you need a new screen.
Top Motorola Mobility Cell Phones Experts
AFIFUL HAQUE MUFTI...
Level 1 Expert
vince
john h
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
