My Amana Oven - AOCS304OSS EvenAir Convection Plus - Electric Wall Oven will not unlock. I set the oven to clean, but needed to cancel real quick...once canceled a flashing/beeping F9 continuously showed. The oven is locked and I cannot get it opened.
Help...need to bake.
The manual does not explain how to fix.
Liz Zervigon
My oven was locked and would not open. No lock light was on but the oven was clearly locked. F9 error when I hit certain buttons.
Try this. I unplugged the oven for about 5 minutes. Plugged back in. A LOCK light came on. Held down "Oven Cancel" for a few seconds. Door opened and lock light went off. No more F9 error when I hit those buttons.
SOURCE: On a Amana EvenAir convection Plus oven the
There is a blower on the top of the oven, which turns on when the oven is hot enough. If the warm/hot air is coming out from top vent corners - this is the blower working. Even if you turn the oven off at that moment, the blower will still work until the oven cools down. This is normal.
If your electric oven is taking too long to heat or just not heating up right, then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
Same exact problem here, any solutions yet?
Same problem oven is locked and when I hit the clean button the F9 flashes and beeps until I hit oven cancel
I have the same problem. What is up with this?
