Hi there:
The only time I have seen horizontal lines in the pictures, it was a prelude to the CCD sensor failing. Sounds like a CCD sensor problem.If the CCD sensor is causing the problem, it will get worse soon.Usually the next thing to happen is that the colors will shift toward pink.
I suggest you phone Photo Local support and tell them the problem and that you suspect the CCD.Ask for a repair quote for a CCD replacement.If the product is under warranty.
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
Hope helps.
SOURCE: Kodak EasyShare P850 - Black screen
I have fixed several Kodak models including this one with exactly the same problem. Sometimes tapping on the side will fix it temporally. The fix is to open the back of the camera and snap the connector from the lens. If the camer is dropped the connector can come unsnapped. You should only attempt this if you have had some experence working on electronics. Be careful inside the camera especially in the upper right corner which is where the high voltage is for the flash. You can get a large shock from this camera if your not careful.
SOURCE: Pinkish screen and green blurred picture
Sounds like the image sensor is malfunctioning (common symptoms: distorted images with purple or green cast, completely dark images, flickering lines across the screen.)
SOURCE: kodak EasyShare C743 takes blurry pictures 80 percent of the time
It is a bad lens focus motor.
SOURCE: Kodak Easyshare camera turns on and off
Hi, here is whats going on, if your M763 is powering on for 2 secs and the lense opens up then go's right back in, there is a 90% chance you got sand in the unit from say the beach ?
here is a test , when you press the power buttion watch the lense you will notice that the bigger part rotates as it comes out, what you want to do is give it a little help Lightly rotate it abit more just at the point where it normaly stops and go's back in, the cam will prob stay on and work like normal.
now the hard part 2 things to try, a can of AIR from walmarts try to blow out and sand thats around the rings, i did this and have fixed about 20 of these's now, on the others you will need to take it apart and clean the gears and mech of the lense housing then put it all back together.
hope this helps
IST tech
Chris
SOURCE: my kodak easyshare M753 has pink tint and lines
its obvious a malfunction that didn't occur by bad handling ..and if the device it is still in the warranty period , my advice is to go for it if you never open it or other things that you wouldn't suppose to do
