I'm stuck on the tree hugger level i can get bart to the end but can't figure out how lisa and the hand of buddah help in saving the two tied to the log!!!!
Basically, you get the hand of Budda and pull out the flashing things above the fires. (They only flash when you are in a Budda position).
Lisa the Tree Hugger
- Enemies: Melee loggers, projectile loggers
- Objective #1: Enter the Auntie Nature logging operation.
Time to take the fight to the loggers and clear cut them into oblivion! Eh, eh?
Anyway, run forward and kick their asses. Lisa has a nifty stun attack with her
sax that leaves enemies paralyzed, which should be useful. Once the first few
loggers are destroyed you can move on to the next area with even more loggers
and the game's first Hand of Buddha port.
- Objective #2: Disable the log conveyor system.
Press Y at the port to activate it and use the Hand. Lift the sections of trees
at the opposite corner of the area and place them on the stumps surrounded by
a green glow. This will create a series of platforms that Bart can use to reach
the lever near the gate and open it. If the loggers start to bother you make
sure you take out the port-o-potty (aka enemy spawner) to prevent any more
loggers from appearing.
In the next area you'll face more loggers and a steam pipe. Man, those loggers
sure like to clog up their steam pipes...
Uh, take Bart and destroy the port-o-potty then switch back to Lisa. Use her
Hand of Buddha to lift the cover off that steam pipe in the corner, creating
one of those convenient updrafts for Bart to use. Get to the top of the
conveyor belt and kick down the trampoline so that Lisa can also get to the
top. From there you simply place Bart and Lisa on the red buttons at the end
and voila: the path is clear.
Run ahead as Bart and clear out those loggers on the high branches before
proceeding into the saw blade area. Before going too far into this place
you should remember to steer clear of the one giant saw blade moving in and
out of the middle section. Once it has moved you'll need to quickly get to
the ladder at the other end and climb to the top of the platform. Shoot the
red target on the left side of the machine to shut down the saw blades and
clear the logs from the path ahead.
Onward, further into the belly of this nature-hating beast! Use Lisa and get
to the Hand of Buddha port at the top of the grassy rock. You'll now have to
lift the section of conveyor belt that's across the green sludge and use that
to build a bridge over the sludge. Once the conveyor belt is placed you can
run into the next area to find another Hand of Buddha and several loggers.
Destroy the port-o-potty then use the Hand of Buddha to lift all of the
radioactive containers onto the moving conveyor belt. That will destroy the
log conveyor system and give you access to the next area.
- Objective #3: Open the floodgates.
Switch to Bart and use the zipline to cross the river. You may as well use
Bart to clear out all the enemies and the enemy spawner on this side of the
river, and once the coast is clear go ahead and pull the lever on the dock.
This will release a flow of logs, crocodiles, and turtles from both sides of
the river. If you get the reference then you, my friend, are old.
- Objective #4: Reconfigure the factory pipes.
Back to Lisa once again. Wait for the logs and creatures to populate the
area then start hopping your way across. Use Lisa's shadow as a guide for
your jumps and you'll get across without a problem.
With both characters on the other side of the river it's nearly time to end
this heinous operation once and for all. Use Lisa to activate the nearby
Hand of Buddha and lift the pipes on the right side. The one you want to move
is the straight vertical pipe, and you'll want to place it on the steam vent
farthest to the right. This will extend the steam updraft so that Bart can
use it to get inside the gated area far to the right.
- Objective #5: Save Lenny and Carl.
Quickly pull the lever and rush Lisa in there to activate the Hand of Buddha.
Use it to lift the branch and save the day! Now if they could only remember
their heroes' names...
- Objective #6: Destroy the factory.
This is it! Switch to Bart and shoot the red target inside the machine to
complete the episode.
what do i do with the hand to stop the saws
can't open the gate and I can't kill the dragan
