How do I change my Robert Shaw RS 3110 from Fahrenheit to Celsius? I do not see any selector switch for that. And pressing and holding the UP/DOWN buttons only change the difference span numbers. Thanks.
First open the unit, as if to remove it from the wall by pressing the release button at the bottom of the unit and tilting it upwards. You should see a bank of 4 dip switches. On my unit these were red. Switch 4 selects temperature units. The circuit board is labelled Fahrenheit. Change this then close your unit and press the reset button.
Degree Format
The oven has been preset to the Fahrenheit temperature scale.
With this feature, users can switch to the Celsius temperature
scale.
To change degree format to Celsius:
1. Press "SETTINGS." Settings menu will appear in display.
2. Press the up or down arrows until "DEGREES:
FAHRENHEIT" appears in the display.
3. Press "ENTER" to change degree format. Current value
will flash.
4. Use arrow keys to select "CELSIUS."
5. Press "ENTER" again to set degree format.
6. To exit the Settings menu, press "SETTINGS."
You will need to press the up or down button after pressing settings until you see Celsius appear then press ENTER and the Celsius flashes then use the arrow key to select Fahrenheit (still flashing) and once again press enter (saves) and it stops flashing. then press settings to exit the settings menu.
Thanks for choosing FixYa,
Kelly
