Is it big enough 2 run a house of 6 of us? wat would the gpm b @ 150 feet
SOURCE: 2 hp vertical sta-rite well pump
Did you prime the pump? To prime: Before turning pump on, unscrew plug cap from top of pump (usually on pump impeller housing,) and with a pitcher or garden hose, fill pump full of water, and replace plug. Then turn pump on and see if problem is solved. If leaking: Are all fittings tight, O-rings and seals new, and is there any pipe thread tape on all threads w/o seals?
SOURCE: Head gasket torque specs
Here you go, I hope this is what you were looking for:
For 1987-94 models, the cylinder head bolts are tightened in 3 progressive steps. Tighten them in the proper sequence as follows:
Step 1: 50-55 ft. lbs. (68-75 Nm)
Step 2: 60-65 ft. lbs. (81-88 Nm)
Step 3: 70-85 ft. lbs. (95-115 Nm)
Let me know if I can assist you with anything else.
SOURCE: we have a Sta-rite mode P2RA50-120L, when trying
If all you are doing is running your filter system to waste or backwash the fact that the pool is over full has nothing to do with it. It should run fine in either case. Your motor is likely starting to fail and as it overheats, shuts off. You may want to consider taking it to a local electric motor shop for repair or replace the motor. That motor is somewhere around $150 from most places. We sell it as well. If you would like a quote, please contact www.arrowmotor.net
SOURCE: Water runs out waste line when pump is running. we
If you already replaced the gasket and upon opeing the valve, it is still in the grooves, look for a crack in the valve body and/or diffuser.
