AM and FM stations work just fine, however even with the antenna put all the way up it rarely picks up any stations unless it is near the broadcasting location. when the antenna is put down it doesnt pick up any radio stations at all besides select AM stations.what might be the cause of this and how can i fix it?
SOURCE: AM radio station work, FM
If the car is from japan the radio if a factory or aftermarket *** radio will start at about 76 and go to 89 it will need a band expander which "shrinks" the frequncey to work on the *** radio
SOURCE: AM radio stations work, FM
If the car is from japan the radio if a factory or aftermarket japanase radio will start at about 76 and go to 89 it will need a band expander which "shrinks" the frequncey to work on the japanase radio
SOURCE: mitsubishi galant 2000 works only AM radio and cd
this usually is caused by either a defective antenna ground to the chassis of the car or a defective antenna or antenna lead to radio.
SOURCE: '97 Mitsubishi Galant starts when jumped, runs
You have a bad battery or bad connections to your battery. Try to charge the battery first. If the problem still occurs then replace the battery. It should be ok after this. good luck.
