Initial Set-Up Plug your wireless router into the cable connection in your wall. Plug the connection cord into the "WAN" port on the router. Plug the router's power source into the wall and turn the router on.Connect your wireless access point to your router by pushing one end of an Ethernet cord into the WAP. Push the other end of the Ethernet cord into the "LAN" port on the router. The WAP connects your wireless devices to your router. Connect your laptop or computer to the WAP. Click the "Start" button on your computer and then click "Control Panel." Click "Network and Internet" and then select "Network and Sharing Center." The "Network and Sharing Center" window opens. Click "Set up a wireless router or access point." Click the "Next" button. Follow the prompts to create a wireless pass phrase or security key. Write the key down in a safe location to ensure access later, if required.
If you have a wireless router and it is connected to the DSLor cable modem then -
To connect to your wireless router, the router needsits wireless settings to be configured with the SSID, encryption key etc., alsothe wireless cards in all the laptops/computers needs to be configured withthese router's wireless settings. Then the laptops/desktop computers cancommunicate with your wireless router and access the Internet via the DSL or cable modem.
To connect to your wireless router, the router needsits wireless settings to be configured with the SSID, encryption key etc., alsothe wireless cards in all the laptops/computers needs to be configured withthese router's wireless settings. Then the laptops/desktop computers can communicatewith your wireless router and access the Internet via the DSL or cable modem.
Connect to one of the wireless router/access point's LAN Ethernet ports, turn off its DHCP server, and give the wireless router a static IP on your LAN:
Connect a PC directly to a LAN port on the wireless router with an Ethernet cable.
Power on the wireless router/access point.
Reboot the PC.
Log in to the wireless router though a browser. (Usually 192.168.1.1, with User Name = admin and Password = password, unless you changed them from the defaults).
Go to the LAN IP menu and disable the wireless access point's DHCP server by unchecking Use router as DHCP server.
Select LAN IP, and change the IP to 192.168.1.99.
Click Apply to save the settings. You will lose the connection to the wireless router/access point , since its IP changed.
Log in to the wireless router/access point with the URL: http://192.168.1.99
Connect one of the wireless router's Local (LAN) ports to your existing network
Depends on the setting of your access point or wireless router. To get the wireless password you need to login to the web-based configuration of your access point or wireless router. To access the router or access point go to your web browser and type in the ip address of your access point or router. login and get your wireless security code there.
To Configure the Router with Internet Access
Reboot the PC.
Go to the LAN IP menu and disable the wireless access point’s DHCP server by unchecking Use router as DHCP server.
Connect one of the wireless router's Local (LAN) ports to your existing network.
This completes the wireless router/access point configuration.
You can now log in to the wireless router/access point at its new address of http://192.168.1.99 and configure wireless features such as WEP and Access Control List
UPnP, DMZ, Port Forwarding, and Port Triggering are not used on the wireless router/access point, and it doesn't matter how they are configured.
Configure the LAN IP address to be within the same subnet as your PCs.
Take care not to use an IP address already being used.
Limit the number of addresses in the DHCP range and assign an IP
address outside of the range to the router you want to use as the
Access Point.
Disable DHCP on the wireless router/access point.
Connect one of the LAN ports on the wireless router/access point to a LAN port on the Router.
Configure the SSID and any security settings on the wireless PCs to match the wireless router/access point's SSID and security settings.
a. SSIDs must be the same on all wireless devices. (These are case-sensitive: netGEAR is not the same as NETGEAR.)
b. Tip: Make sure the wireless PCs can connect before configuring WEP, WPA-PSK, or other wireless encryption.
You'll needing to access the configuration page of your router (ei 192.168.1.1), to make it accessible you'll needing to create a wireless network name and security or encryption to the router (ei WEP or WPA)
Your sister was accessing the wireless access point at school which is connected to the Internet/WEB access via a router and the school's broadband service provider.
For you to access the Internet using your wireless adapter on your laptop, you need your own wireless access point and connect it to a broadband ADSL or cable modem and then connect it to an Internet Service Provider. Some Internet Service Providers (cable and ADSL) can supply a combined modem/router/wireless Access point.
If you already have a broadband modem all you need is a wireless access point/router. You only need to configure the wireless access point and your wireless adapter so they will communicate with each other. Folow the instructions in the manuals.
Yes you can use it as an access point and hook it to your existing router, since this is a wireless router and can work as a wireless access point on your network............
If your router is not wireless capable you need to add "wireless access point" on your network so that your wireless computers will be able to connect wirelessly to your network. You can buy WAP54G of Linksys or other brand of WAP(wireless access point).
